[GRASS-dev] Fwd: Re: [gdal-dev] Setting NODATA to -nan
Sat Jul 18 03:48:24 PDT 2015
Yann Chemin wrote:
> it might be that some communication improvement from GRASS-GDAL could be
> done?
> is there a clear NODATA/NAN definition understood within GDAL that we could
> use within r.out.gdal as a target NODATA value whenever anything than a
> number is used (i.e. NaN, nan, -nan, helloworld, mynameisbee, etc.)
> typically MODIS users are used to -28768 and similar "standard" NODATA
> numbers, but that maybe another story.
IMHO, anything using NaN as a no-data value should treat all NaNs
equally. The reason being that the only way to reliably propagate the
representation for a NaN is to memcpy() it. Assignment only preserves
NaN-ness, not necessarily the representation.
Actually, r.external is doing it wrong, as it expects any NaNs
supplied by GDAL to exactly match the representation generated by
Rast_set_d_null_value() (the all-ones bit pattern).
Fixed in r65602.
And if the no-data value isn't NaN, you have the issue of comparing
floating-point values for equality. Well, that will probably work so
long as the chosen no-data value is an integer.
