[GRASS-dev] [GRASS GIS] #2218: r.stream.order: lack of documentation for flow_accum column in attribute table
trac at osgeo.org
Mon Jul 20 03:58:39 PDT 2015
table
Reporter: mlennert | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.0
Component: Addons | Version: svn-releasebranch70
Resolution: | Keywords: r.stream.order, flow_accum
CPU: Unspecified | Platform: Unspecified
Changes (by madi):
* owner: Madi => grass-dev@…
Comment:
fwiw, I made some manual calculations in order to establish what the
column 'flow_accum' represents. My hypothesis was that it represented the
difference between the value of flow accum in the node downstream minus
the accum in the node upstream. But my hypothesis was not verified,
although the magnitude is comparable. If someone has better ideas I'm
ready to test. Thanks
Ticket URL: <https://trac.osgeo.org/grass/ticket/2218#comment:4>
