[GRASS-dev] Fwd: OSX El Capitan Beta breaks GRASS g.gui
Carlos Grohmann
carlos.grohmann at gmail.com
Mon Jul 20 08:54:48 PDT 2015
Hi.
I'm on the Apple Beta Program and the new upgrade to OSX 10.11 El Capitan
just broke g.gui.
This is the error message from version 6.4.4:
> g.gui
Launching 'wxpython' GUI in the background, please wait ...
File "/Applications/GRASS-6.4.app/Contents/MacOS/etc/wxpython/wxgui.py",
line 27, in <module>
from core import globalvar
File
"/Applications/GRASS-6.4.app/Contents/MacOS/etc/wxpython/core/globalvar.py",
line 74, in <module>
import wx
File
"/Applications/GRASS-6.4.app/Contents/MacOS/etc/python/wx/__init__.py",
line 45, in <module>
from wx._core import *
File "/Applications/GRASS-6.4.app/Contents/MacOS/etc/python/wx/_core.py",
line 4, in <module>
import _core_
ImportError:
dlopen(/Applications/GRASS-6.4.app/Contents/MacOS/etc/python/wx/_core_.so,
2): Library not loaded:
/Users/Shared/unix/wxpython-cocoa-lion/lib/libwx_osx_cocoau-3.0.dylib
Referenced from:
Reason: image not found
The library that was not founded is available but not in the specified path:
> locate libwx_osx_cocoau-3.0.dylib
/Applications/GRASS-6.4.app/Contents/MacOS/lib/libwx_osx_cocoau-3.0.dylib
/Applications/QGIS.app/Contents/MacOS/lib/libwx_osx_cocoau-3.0.dylib
/usr/local/lib/wxPython-3.0.2.0/lib/libwx_osx_cocoau-3.0.dylib
One question O think of is: if GRASS ships the wx libraries, why reference
the system one at /Users/Shared/unix/...?
With GRASS 7.0, libgrass_gis is the one not being loaded, and in the end,
not even in text mode it will start:
$ /Applications/GRASS-7.0.app/Contents/MacOS/grass.sh
Rebuilding Addon HTML manual pages index...
Rebuilding Addon menu...
Python 2.7.6 found.
Cleaning up temporary files...
Starting GRASS GIS...
dyld: Library not loaded:
/Applications/GRASS/GRASS-7.0.app/Contents/MacOS/lib/libgrass_gis.7.0.0.dylib
Referenced from: /Applications/GRASS-7.0.app/Contents/MacOS/bin/g.gisenv
File
"/Applications/GRASS-7.0.app/Contents/MacOS/gui/wxpython/gis_set.py", line
31, in <module>
File
"/Applications/GRASS-7.0.app/Contents/MacOS/gui/wxpython/core/globalvar.py",
line 29, in <module>
from core.debug import Debug
File
"/Applications/GRASS-7.0.app/Contents/MacOS/gui/wxpython/core/debug.py",
line 66, in <module>
Debug = DebugMsg()
File
line 37, in __init__
self.SetLevel()
File
line 42, in SetLevel
self.debuglevel = int(grass.gisenv().get('WX_DEBUG', 0))
File
"/Applications/GRASS-7.0.app/Contents/MacOS/etc/python/grass/script/core.py",
line 902, in gisenv
s = read_command("g.gisenv", flags='n')
File
line 424, in read_command
process = pipe_command(*args, **kwargs)
File
line 399, in pipe_command
return start_command(*args, **kwargs)
File
line 354, in start_command
if debug_level() > 0:
File
line 1485, in debug_level
_debug_level = int(gisenv().get('DEBUG', 0))
File
line 902, in gisenv
File
line 427, in read_command
return handle_errors(returncode, stdout, args, kwargs)
File
line 310, in handle_errors
returncode=returncode)
grass.exceptions.CalledModuleError: Module run None ['g.gisenv', '-n']
ended with error
Process ended with non-zero return code -5. See errors in the (error)
output.
Error in GUI startup. If necessary, please report this error to the GRASS
developers.
Switching to text mode now.
Hit RETURN to continue...
File "/Applications/GRASS-7.0.app/Contents/MacOS/grass70", line 1422, in
<module>
set_data()
File "/Applications/GRASS-7.0.app/Contents/MacOS/grass70", line 670, in
set_data
gui_startup(grass_gui == 'gtext')
File "/Applications/GRASS-7.0.app/Contents/MacOS/grass70", line 692, in
gui_startup
os.execlp(cmd_name, "-text")
File
"/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/os.py",
line 327, in execlp
execvp(file, args)
File
line 344, in execvp
_execvpe(file, args)
File
line 380, in _execvpe
func(fullname, *argrest)
OSError: [Errno 2] No such file or directory
Maybe later today i'll try to compile G7.
best
Carlos
Prof. Carlos Henrique Grohmann
Institute of Energy and Environment - Univ. of São Paulo, Brazil
- Digital Terrain Analysis | GIS | Remote Sensing -
http://carlosgrohmann.com
http://orcid.org/0000-0001-5073-5572
________________
Can’t stop the signal.
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20150720/26b05384/attachment-0001.html>
