[GRASS-dev] compiling on OSX 10.11 (El Capitan Beta)
Carlos Grohmann carlos.grohmann at gmail.com
Wed Jul 22 10:36:59 PDT 2015
Hi
I'm trying to compile GRASS7 on OSX 10.11 Beta, but I'm stuck with GDAL.
I'm using Kyngesburye's frameworks, and I have gdal-config in my PATH as
export PATH=/Library/Frameworks/GDAL.framework/Programs:$PATH
this minimum example of configure fails:
export MACOSX_DEPLOYMENT_TARGET=10.10
./configure \
> --prefix=/Applications \
> --enable-macosx-app \
> --with-macosx-archs="x86_64" \
--with-macosx-sdk=/Applications/Xcode.app/Contents/Developer/Platforms/MacOSX.platform/Developer/SDKs/MacOSX10.10.sdk/
> --with-proj \
> --with-proj-includes=/Library/Frameworks/PROJ.framework/unix/include \
> --with-proj-libs=/Library/Frameworks/PROJ.framework/unix/lib \
> --with-proj-share=/Library/Frameworks/PROJ.framework/Resources/proj \
> --with-gdal=/Library/Frameworks/GDAL.framework/Programs/gdal-config \
checking host system type... x86_64-apple-darwin15.0.0
checking for gcc... gcc
checking whether the C compiler (gcc -Os ) works... yes
checking whether the C compiler (gcc -Os ) is a cross-compiler... no
checking whether we are using GNU C... yes
checking whether gcc accepts -g... yes
checking for Cygwin environment... no
checking for mingw32 environment... no
checking for executable suffix... no
checking for full floating-point support... yes
checking for pwd... /bin/pwd
checking for source directory...
/Users/guano/Documents/installs/grass70_release
checking for build directory...
checking for svnversion... /usr/bin/svnversion
checking for MacOSX App... yes
checking for MacOSX architectures...  -arch x86_64
checking for MacOSX SDK... checking for
/Applications/Xcode.app/Contents/Developer/Platforms/MacOSX.platform/Developer/SDKs/MacOSX10.10.sdk//SDKSettings.plist...
yes
checking how to build libraries... shared
checking for additional include dirs...
checking for additional library dirs...
checking for a BSD compatible install... /usr/bin/install -c
checking for flex... flex
checking for yywrap in -lfl... no
checking for bison... bison -y
checking for ranlib... ranlib
checking for ar... ar
checking for env... env
checking for perl... /usr/bin/perl
checking how to run the C preprocessor... gcc -E
checking for ANSI C header files... yes
checking for limits.h... yes
checking for termio.h... no
checking for termios.h... yes
checking for unistd.h... yes
checking for values.h... no
checking for f2c.h... no
checking for g2c.h... no
checking for sys/ioctl.h... yes
checking for sys/mtio.h... no
checking for sys/resource.h... yes
checking for sys/time.h... yes
checking for sys/timeb.h... yes
checking for sys/types.h... yes
checking for sys/utsname.h... yes
checking for libintl.h... no
checking for iconv.h... yes
checking for langinfo.h... yes
checking whether time.h and sys/time.h may both be included... yes
checking for off_t... yes
checking for uid_t in sys/types.h... yes
checking return type of signal handlers... void
checking for ftime... yes
checking for gethostname... yes
checking for gettimeofday... yes
checking for lseek... yes
checking for nice... yes
checking for time... yes
checking for uname... yes
checking for seteuid... yes
checking for setpriority... yes
checking for setreuid... yes
checking for setruid... yes
checking for drand48... yes
checking for putenv... yes
checking for setenv... yes
checking for nanosleep... yes
checking whether setpgrp takes no argument... yes
checking for long long int... yes
checking for W11... no
checking for X... no
checking for library containing cuserid... no
checking for asprintf... yes
checking for atan... yes
checking for dlsym... yes
checking for iconv... no
checking for iconv in -liconv... yes
checking for socket... yes
checking for location of zlib includes...
checking for zlib.h... yes
checking for location of zlib library...
checking for deflate in -lz... yes
checking for location of External PROJ.4 includes...
checking for proj_api.h... yes
checking External PROJ.4 version... 491
checking for location of External PROJ.4 library...
checking for pj_get_def in -lproj... yes
checking for location of External PROJ.4 data files...
checking for /Library/Frameworks/PROJ.framework/Resources/proj/epsg... yes
checking for nad2bin...
/Library/Frameworks/PROJ.framework/Versions/Current/Programs//nad2bin
checking whether to use regex... yes
checking for location of regex includes...
checking for regex.h... yes
checking for location of regex library...
checking for regcomp... yes
checking whether to use Readline... no
checking whether to use GDAL... yes
checking for gdal-config...
configure: error: *** Unable to locate GDAL library.
This is the last part of config.log:
configure:6036: checking whether to use GDAL
configure:6054: checking for gdal-config
configure:6116: gcc -o conftest -Os   -arch x86_64 -isysroot
-I/Library/Frameworks/GDAL.framework/Versions/1.11/Headers    -arch x86_64
-isysroot
 conftest.c  -framework GDAL 1>&5
configure:6112:1: warning: ignoring return value of function declared with
warn_unused_result attribute [-Wunused-result]
GDALOpen("foo", GA_ReadOnly);
1 warning generated.
ld: framework not found GDAL
clang: error: linker command failed with exit code 1 (use -v to see
invocation)
configure: failed program was:
#line 6109 "configure"
#include "confdefs.h"
#include <gdal.h>
int main() {
; return 0; }
configure:6132: gcc -o conftest -Os   -arch x86_64 -isysroot
-isysroot
configure:6128:1: warning: ignoring return value of function declared with
invocation)
#line 6125 "configure"
#include <gdal.h>
int main() {
; return 0; }
looking for gdal-config:
which gdal-config
and for gdal.h:
locate gdal.h
/Applications/GRASS-6.4.app/Contents/MacOS/docs/html/r.in.gdal.html
/Applications/GRASS-6.4.app/Contents/MacOS/docs/html/r.out.gdal.html
/Applications/GRASS-7.0.app/Contents/MacOS/docs/html/r.in.gdal.html
/Applications/GRASS-7.0.app/Contents/MacOS/docs/html/r.out.gdal.html
/Applications/QGIS.app/Contents/MacOS/grass/docs/html/r.in.gdal.html
/Applications/QGIS.app/Contents/MacOS/grass/docs/html/r.out.gdal.html
/Library/Frameworks/GDAL.framework/Versions/1.10/Headers/gdal.h
/Library/Frameworks/GDAL.framework/Versions/1.10/Resources/doc/gdal/java/org/gdal/gdal/gdal.html
/Library/Frameworks/GDAL.framework/Versions/1.11/Headers/gdal.h
/Library/Frameworks/GDAL.framework/Versions/1.11/Resources/doc/gdal/java/org/gdal/gdal/gdal.html
So it looks to me that configure is looking at the right place for gdal.h...
any ideas?
thanks
Carlos
Prof. Carlos Henrique Grohmann
Institute of Energy and Environment - Univ. of São Paulo, Brazil
- Digital Terrain Analysis | GIS | Remote Sensing -
http://carlosgrohmann.com
http://orcid.org/0000-0001-5073-5572
________________
Can’t stop the signal.
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20150722/0a30f1e6/attachment-0001.html>
