[GRASS-dev] compiling on OSX 10.11 (El Capitan Beta)
Carlos Grohmann
carlos.grohmann at gmail.com
Fri Jul 24 06:52:49 PDT 2015
Well, if the errors are only about documentation, I can live with them.
So I went on to create the installation package. I had to manually download
PackageMaker from Apple (Late 2012 version).
After creating and installing the package, when I run it, I get the startup
dialog (choose location etc), but wxgui fails:
Launching <wxpython> GUI in the background, please wait...
GRASS 7.0.1RC2
(araca_utm):~/Documents/installs/release_20150720_grass_7_0_1RC2 > Unable
to import pyGRASS: grass_gis.7.0.1RC2 not found.
Some functionality will be not accessible
File "/Applications/GRASS-7.0.app/Contents/MacOS/gui/wxpython/wxgui.py",
line 37, in <module>
from lmgr.frame import GMFrame
File
"/Applications/GRASS-7.0.app/Contents/MacOS/gui/wxpython/lmgr/frame.py",
line 50, in <module>
from lmgr.layertree import LayerTree, LMIcons
File
"/Applications/GRASS-7.0.app/Contents/MacOS/gui/wxpython/lmgr/layertree.py",
from mapdisp.frame import MapFrame
File
"/Applications/GRASS-7.0.app/Contents/MacOS/gui/wxpython/mapdisp/frame.py",
line 34, in <module>
from vdigit.toolbars import VDigitToolbar
File
"/Applications/GRASS-7.0.app/Contents/MacOS/gui/wxpython/vdigit/toolbars.py",
line 30, in <module>
from iclass.digit import IClassVDigit
File
"/Applications/GRASS-7.0.app/Contents/MacOS/gui/wxpython/iclass/digit.py",
line 23, in <module>
from vdigit.wxdisplay import DisplayDriver, TYPE_AREA
ImportError: cannot import name TYPE_AREA
Carlos
On Thu, Jul 23, 2015 at 10:35 PM, William Kyngesburye <woklist at kyngchaos.com
> wrote:
> I believe what happens is it compiles with links to where it will be
> installed, but during documentation creation it uses DYLD_LIBRARY_PATH to
> make it look in the build dir. This is what is not working.
> On Jul 23, 2015, at 7:40 PM, Carlos Grohmann <carlos.grohmann at gmail.com>
> wrote:
> > On thing that I found weird id this:
> > dyld: Library not loaded:
> /Applications/GRASS-7.0.app/Contents/MacOS/lib/libgrass_gis.7.0.1RC2.dylib
> > Referenced from:
> /Users/guano/Documents/installs/release_20150720_grass_7_0_1RC2/dist.x86_64-apple-darwin15.0.0/bin/g.parser
> > Reason: image not found
> > Why load the library from /Applications/GRASS-7.0.app/ at compiling
> time? The package hasn't even been created yet...
> > Shouldn't this be loaded from the source dir?
> > Carlos
> > On Thu, Jul 23, 2015 at 12:09 AM, William Kyngesburye <
> woklist at kyngchaos.com> wrote:
> > I don't see any GDAL problem there. It looks like DYLD_LIBRARY_PATH is
> not working when running the modules to create documentation.
> > I don't know where to go from there.
> > On Jul 22, 2015, at 8:18 PM, Carlos Grohmann <carlos.grohmann at gmail.com>
> wrote:
> > > Thanks, William.
> > > That worked, at least for the configure part. Now the problem is at
> compiling. At the end of make, I get a ton of errors in modules:
> > > the first script, d.correlate, gives me this eror:
> > > cd scripts/d.correlate/
> > > GuanoAFBIOTA:d.correlate guano$ make
> > > if [
> "/Users/guano/Documents/installs/grass70_release/dist.x86_64-apple-darwin15.0.0/scripts/d.correlate"
> != "" ] ; then
> GISRC=/Users/guano/Documents/installs/grass70_release/dist.x86_64-apple-darwin15.0.0/demolocation/.grassrc70
> GISBASE=/Users/guano/Documents/installs/grass70_release/dist.x86_64-apple-darwin15.0.0
> PATH="/Users/guano/Documents/installs/grass70_release/dist.x86_64-apple-darwin15.0.0/bin:/Users/guano/Documents/installs/grass70_release/dist.x86_64-apple-darwin15.0.0/bin:/Users/guano/Documents/installs/grass70_release/dist.x86_64-apple-darwin15.0.0/scripts:$PATH"
> PYTHONPATH="/Users/guano/Documents/installs/grass70_release/dist.x86_64-apple-darwin15.0.0/etc/python:/Users/guano/Documents/installs/grass70_release/dist.x86_64-apple-darwin15.0.0/gui/wxpython:$PYTHONPATH"
> DYLD_LIBRARY_PATH="/Users/guano/Documents/installs/grass70_release/dist.x86_64-apple-darwin15.0.0/bin:/Users/guano/Documents/installs/grass70_release/dist.x86_64-apple-darwin15.0.0/scripts:/Users/guano/Documents/installs/grass70_release/dist.x86_64-apple-darwin15.0.0/lib:/Users/guano/Documents/installs/grass70_release/dist.x86_64-apple-darwin15.0.0/lib:"
> LC_ALL=C
> --html-description < /dev/null | grep -v '</body>\|</html>' >
> d.correlate.tmp.html ; fi
> /Applications/GRASS-7.0.app/Contents/MacOS/lib/libgrass_gis.7.0.1svn.dylib
> > > Referenced from:
> /Users/guano/Documents/installs/grass70_release/dist.x86_64-apple-darwin15.0.0/bin/g.parser
> > > make: *** [d.correlate.tmp.html] Error 1
> > > rm d.correlate.tmp.html
> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
> http://www.kyngchaos.com/
> "We are at war with them. Neither in hatred nor revenge and with no
> particular pleasure I shall kill every ___ I can until the war is over.
> That is my duty."
> "Don't you even hate 'em?"
> "What good would it do if I did? If all the many millions of people of the
> allied nations devoted an entire year exclusively to hating the ____ it
> wouldn't kill one ___ nor shorten the war one day."
> <Ha, ha> "And it might give 'em all stomach ulcers."
> - Tarzan, on war
Prof. Carlos Henrique Grohmann
Institute of Energy and Environment - Univ. of São Paulo, Brazil
- Digital Terrain Analysis | GIS | Remote Sensing -
http://carlosgrohmann.com
http://orcid.org/0000-0001-5073-5572
________________
Can’t stop the signal.
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20150724/3610afe8/attachment-0001.html>
