[GRASS-dev] [GRASS GIS] #2434: v.surf.bspline: WARNING: Unable to rename null file / WARNING: Unable to write quant rules:
trac at osgeo.org
Sun Jul 26 01:35:20 PDT 2015
write quant rules:
Reporter: baharmon | Owner: grass-dev@…
Type: defect | Status: new
Priority: major | Milestone: 7.0.1
Component: Raster | Version: svn-releasebranch70
Resolution: | Keywords: v.surf.bspline
CPU: OSX/Intel | Platform: MSWindows 8
Comment (by hellik):
Replying to [comment:11 annakrat]:
> How to reproduce (taken from #2597):
> g.region rast=elevation res=100
> v.random out=points n=1000 -z zmax=100
> v.surf.bspline in=points raster_o=surf ns=100 ew=100
tested here with
System Info
GRASS Version: 7.1.svn
GRASS SVN revision: 65777
Build date: 2015-07-25
Build platform: i686-pc-mingw32
GDAL: 1.11.2
PROJ.4: 4.8.0
GEOS: 3.4.2
SQLite: 3.7.17
Python: 2.7.4
wxPython: 2.8.12.1
Platform: Windows-Vista-6.0.6002-SP2 (OSGeo4W)
and the example from the manual
g.region -p region=rural_1m at PERMANENT res=2
v.surf.bspline --verbose input=elev_lid792_bepts at PERMANENT
raster_output=elev_lid792_rast ew_step=5 ns_step=5 method=bicubic
lambda_i=0.1 memory=900
Input is 3D: using z-coordinates for approximation
Zellen für die Rasterkarte <elev_lid792_rast> werden interpoliert.
Initialisiere die Ausgabe...
Adjusted EW splines 121
Adjusted NS splines 131
Processing subregion 1 of 4...
16805 points found in this subregion
Processing subregion 2 of 4...
13741 points found in this subregion
Processing subregion 3 of 4...
13512 points found in this subregion
Processing subregion 4 of 4...
11564 points found in this subregion
Schreibe Ausgabe...
'J:\gisdata\nc_spm_08_grass7\user1\.tmp/unknown\5848.1' to
'J:\gisdata\nc_spm_08_grass7\user1\cell_misc\elev_lid792_rast\null':
Permission denied
WARNING: Unable to rename cell file
'J:\gisdata\nc_spm_08_grass7\user1\.tmp/unknown\5848.0' to
'J:\gisdata\nc_spm_08_grass7\user1\fcell\elev_lid792_rast': Permission
denied
WARNING: Unable to write quant rules: raster map <elev_lid792_rast> is
integer
v.surf.bspline komplett.
(Sun Jul 26 10:30:40 2015) Befehl ausgeführt (38 Sek)
bug report still valid.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2434#comment:14>
