[GRASS-dev] Travis CI
Rainer M Krug
Rainer at krugs.de
Tue Jul 28 06:50:26 PDT 2015
Markus Neteler <neteler at osgeo.org> writes:
> On Tue, Jul 28, 2015 at 3:39 PM, Rainer M Krug <Rainer at krugs.de> wrote:
>>> If you tell me where (on which page in the wiki or on a new page?), I could probably add it this evening - Oh -
>>> do I need write access to the wiki?
> Yes. "Thanks" to the spammers we cannot avoid that.
> There is a related registration link as in any Mediawiki instance.
>> Would http://grasswiki.osgeo.org/wiki/Compile_and_Install#Mac_OSX be
>> appropriate? It seems that I can just edit it and do not need special
>> access there?
> You need to register.
> Perhaps you want to write it up in a separate page and link there in
> order to avoid that the main Compile_and_Install page gets too long.
Good idea. I just started this.
Thanks,
Rainer
> Markus
>> Rainer
>>> Thanks,
>>> Rainer
>>>> Markus
>> Rainer M. Krug, PhD (Conservation Ecology, SUN), MSc (Conservation Biology, UCT), Dipl. Phys. (Germany)
>> Centre of Excellence for Invasion Biology
>> Stellenbosch University
>> South Africa
>> Tel : +33 - (0)9 53 10 27 44
>> Cell: +33 - (0)6 85 62 59 98
>> Fax : +33 - (0)9 58 10 27 44
>> Fax (D): +49 - (0)3 21 21 25 22 44
>> email: Rainer at krugs.de
>> Skype: RMkrug
>> PGP: 0x0F52F982
South Africa
Skype: RMkrug
PGP: 0x0F52F982
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20150728/d0590157/attachment.pgp>
