[GRASS-dev] [GRASS GIS] #2140: m.proj does not handle cs2cs failure
trac at osgeo.org
Thu Jul 30 18:06:01 PDT 2015
Reporter: wenzeslaus | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.0
Component: Projections/Datums | Version: svn-trunk
Resolution: | Keywords: m.proj, cs2cs
CPU: All | Platform: All
Comment (by jrobparsons):
This is interesting...
Output from GRASS GUI Command Console
(Thu Jul 30 20:38:52 2015)
m.proj input=test.txt proj_out=bla bla bla proj_in=another bla bla bla
Rel. 4.8.0, 6 March 2012
<cs2cs.EXE>:
projection initialization failure
cause: Unknown error
program abnormally terminated
ERROR: Using from definition:
(Thu Jul 30 20:38:54 2015) Command finished (1 sec)
Output from GRASS Command Line
C:\>m.proj input=test.txt proj_out=bla bla bla proj_in=another bla bla bla
Description:
Converts coordinates from one projection to another (cs2cs frontend).
Keywords:
miscellaneous, projection
Usage:
m.proj.py [-iodec] [coordinates=east,north] [input=name] [output=name]
[separator=character] [proj_in=string] [proj_out=string] [--overwrite]
[--help] [--verbose] [--quiet] [--ui]
Flags:
-i Use LL WGS84 as input and current location as output projection
-o Use current location as input and LL WGS84 as output projection
-d Output long/lat in decimal degrees, or other projections with many
decimal places
-e Include input coordinates in output file
-c Include column names in output file
--o Allow output files to overwrite existing files
--h Print usage summary
--v Verbose module output
--q Quiet module output
--ui Force launching GUI dialog
Parameters:
coordinates Input coordinates to reproject
input Name of input coordinate file
'-' for standard input
output Name for output coordinate file (omit to send to stdout)
separator Field separator (format: input[,output])
Special characters: pipe, comma, space, tab, newline
default: pipe
proj_in Input projection parameters (PROJ.4 style)
proj_out Output projection parameters (PROJ.4 style)
ERROR: Sorry <bla> is not a valid option
C:\>
Ticket URL: <https://trac.osgeo.org/grass/ticket/2140#comment:5>
GRASS GIS, commonly referred to as GRASS (Geographic Resources Analysis Support System), is a free and open source Geographic Information System (GIS) software suite used for geospatial data management and analysis, image processing, graphics and maps production, spatial modeling, and visualization. GRASS GIS is currently used in academic and commercial settings around the world, as well as by many governmental agencies and environmental consulting companies. It is a founding member of the Open Source Geospatial Foundation (OSGeo).
