[GRASS-dev] [GRASS GIS] #2686: r.hazard.flood error output
GRASS GIS trac at osgeo.org
Mon Jun 1 07:22:55 PDT 2015
 Reporter:  zimbogisgeek  |      Owner:  grass-dev@…
     Type:  defect        |     Status:  new
 Priority:  critical      |  Milestone:  7.0.1
Component:  Python        |    Version:  svn-releasebranch70
 Keywords:                |        CPU:  All
 Platform:  All           |
 Running r.hazard.flood produces an erroneous map mainly because in the
 r.hazard.py script there is a mistake in calculating the final map. The
 command that produces the error is
 grass.mapcalc("$r_flood_map = $rast1 / $rast1", r_flood_map = r_flood_map,
 rast1 = 'r_flood_th')
 which should be
  grass.mapcalc("$r_flood_map = $rast1 / $rast2", r_flood_map =
 r_flood_map, rast1 = 'r_flood_th', rast2 = 'r_flood')
Ticket URL: <https://trac.osgeo.org/grass/ticket/2686>
