[GRASS-dev] [GRASS GIS] #2349: CELL raster format: make ZLIB level 3 standard compression instead of RLE
GRASS GIS trac at osgeo.org
Sat Jun 6 10:13:38 PDT 2015
  Reporter:  neteler      |      Owner:  grass-dev@…
      Type:  enhancement  |     Status:  new
  Priority:  critical     |  Milestone:  7.1.0
 Component:  Raster       |    Version:  svn-trunk
Resolution:               |   Keywords:  compression, r.compress, null
       CPU:  Unspecified  |   Platform:  All
Comment (by glynn):
 Replying to [comment:35 martinl]:
 > by "fix" you mean to ignore GRASS_TMPDIR_MAPSET when working with raster
 data?
 Yes. I don't particularly want to do anything with lib/raster while that's
 outstanding (the tempfile changes broke Rast!__close_null(); while a
 workaround would be trivial, that's symptomatic of the sort of thing that
 happens when two people are working on the same code concurrently).
Ticket URL: <https://trac.osgeo.org/grass/ticket/2349#comment:36>
