[GRASS-dev] wingrass standalone default options, Microsoft Runtime Libraries
Helmut Kudrnovsky hellik at web.de
Sun Jun 7 02:08:55 PDT 2015
Martin Landa wrote
> Hi all,
> it seems to me that to enable installing Important Microsoft Runtime
> Libraries is crucial when installing GRASS using standalone installer
> on newer versions of Windows.
> I wonder if it would make sense to enable it by default (now it's
> uncheck). What do you think? Thanks, Martin
maybe a better way would be to check if the needed runtime libraries are
already installed?
unfortunately I've never found an easy and feasible way for checking this.
so a +0 for a default install of a Microsoft Runtime Libraries.
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/wingrass-standalone-default-options-Microsoft-Runtime-Libraries-tp5209586p5209587.html
Sent from the Grass - Dev mailing list archive at Nabble.com.
