[GRASS-dev] [GRASS GIS] #2021: encoding information in locale gets lost
trac at osgeo.org
Wed Jun 10 03:37:57 PDT 2015
Reporter: mlennert | Owner: grass-dev@…
Type: defect | Status: reopened
Priority: normal | Milestone: 7.0.1
Component: Startup | Version: svn-trunk
Resolution: | Keywords: locale encoding
CPU: Unspecified | Platform: Linux
Comment (by mlennert):
Replying to [comment:4 marisn]:
> Replying to [comment:3 mlennert]:
> > Reopening this, as with a fairly fresh trunk (r65364), I get:
> Please provide locale line from GRASS wx configuration file.
> set_language() kicks in only if a language override is requested within
wxgui settings.
Yep, that was it. There was an override in the wx config file.
However, this is quite confusing as I was not even using the wxgui. I
don't think wxgui config should interfere with command line.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2021#comment:5>
