[GRASS-dev] r65348: Mapset's tmp dir placement and broken element search
Wed Jun 10 08:41:48 PDT 2015
Vaclav Petras wrote:
> First, it allows unorthodox behavior of GRASS but this behavior is (or at
> least should be) applied only when GRASS_TMPDIR_MAPSET is set to some
> specific value. I don't see much problem with it as long as the
> documentation properly discuss all the potential issues and the default is
> the standard and safe way. This was discussed in [GRASS-dev] r65348
> (GRASS_TMPDIR_MAPSET).
There is no justification for the current behaviour. The temporary
cell/fcell and null files should always be created in the mapset's
temporary directory.
