[GRASS-dev] [GRASS GIS] #2021: encoding information in locale gets lost
trac at osgeo.org
Thu Jun 11 00:51:26 PDT 2015
Reporter: mlennert | Owner: grass-dev@…
Type: defect | Status: reopened
Priority: normal | Milestone: 7.0.1
Component: Startup | Version: svn-trunk
Resolution: | Keywords: locale encoding
CPU: Unspecified | Platform: Linux
Comment (by marisn):
Hm. Probably set_language should be moved to some place to kick-in only if
a GUI session is started.
Rant:
The architectural problem lies in the fact that GRASS is not a monolithic
app as i.e. QGIS. GUI's can be started from CLI and there are CLI apps too
(and, of course, "native" widgets like "open file"!). Thus setting a
language in wxgui tries to cover all potential aspects to ensure a
constant user experience.
The problem areas are: lack of target locale on particular system (only
GRASS messages will be translated); incorrect default encoding (i.e. for
Latvian language Python is certain that Win-1257 is the best thing on my
UTF-8 Linux box and then hell breaks loose!); enforcing language on
everything (cal; "OK" and "Cancel" buttons; all GRASS module output as it
might be piped back to GUI; did I forgot something?
As one can see - it is easy to mess something up and "quick fixes" need to
ensure covering most of aspects as it is too easy to make things worse.
(just check my own commits for language switching and you will see that it
is true ;) )
Ticket URL: <https://trac.osgeo.org/grass/ticket/2021#comment:6>
