[GRASS-dev] [GRASS GIS] #2690: PEP8 like code styling for the i.tasscap.py script
GRASS GIS trac at osgeo.org
Thu Jun 11 00:54:59 PDT 2015
  Reporter:  nikosa       |      Owner:  grass-dev@…
      Type:  enhancement  |     Status:  new
  Priority:  trivial      |  Milestone:  7.0.1
 Component:  Python       |    Version:  unspecified
Resolution:               |   Keywords:  i.tassccap, python, script
       CPU:  Unspecified  |   Platform:  Unspecified
Comment (by nikosa):
 Replying to [comment:1 wenzeslaus]:
 > Seems OK. Did you check what you get from `svn diff --ignore-space-
 change` or `svn diff --ignore-all-space`?
 Attached diffs derived from `svn diff -x '--ignore-all-space'` and `svn
 diff -x '--ignore-space-change'`.
 > I would ask you for simple test which would prove that the basic
 functionality is OK but it would be probably absurd to require it when we
 lack tests for far more invasive changes.
 At minimum, I have tested the script before submitting the (first) diff
 and it work-ed/-s for me.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2690#comment:2>
