[GRASS-dev] [GRASS GIS] #2593: Use GRASS GIS 7 for module of the day
trac at osgeo.org
Thu Jun 11 10:14:48 PDT 2015
Reporter: wenzeslaus | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: Website
Component: Website | Version: unspecified
Resolution: | Keywords: php
CPU: Unspecified | Platform: Unspecified
Comment (by wenzeslaus):
Well, the code has a few strange places which would use some refactoring,
but anyway, I think that the change should be applied everywhere:
#!diff
- while (substr($a[$ra], 0, 27) != "<tr><td valign=top><a href=")
+ while (substr($a[$ra], 0, 29) != "<tr><td valign=\"top\"><a href=")
This will need to be changed next time the HTML file will be changed, e.g.
replacing attributes by styles or change in formatting. Besides possible
refactoring of this PHP, the complete solution I have in mind for some
time already is to have XML, CSV, JSON and plain text files generated
automatically and available online. These files could be used by tools
like this one (or some interactive manual pages) for searching and showing
info about modules without parsing of HTML which can change anytime.
For the "random" part this should be changed too (just optimization and
avoiding a warning):
#!diff
- $ra = rand(0, 1000);
+ $ra = rand(0, count($a));
I'm not sure how the "day" part should be changed if at all, but there are
some magic numbers as well.
BTW, I saved the file and then executed in command line using `php
grass_moday.php`. I had to add `<?php` at the beginning and `?>` at the
end. I also downloaded the
[http://grass.osgeo.org/grass70/manuals/full_index.html full_index.html]
file (`wget http://grass.osgeo.org/grass70/manuals/full_index.html`)
BTW2, these things are not in grass-web repository? Why not? Are they too
intimate, i.e. too many strange paths etc.? Or too much management
overhead?
Ticket URL: <https://trac.osgeo.org/grass/ticket/2593#comment:11>
