[GRASS-dev] how to work around "Arument list too long" error in a GRASS python script ?
Moritz Lennert
mlennert at club.worldonline.be
Thu Jun 11 10:46:16 PDT 2015
On 11/06/15 19:02, Nikos Alexandris wrote:
> * Moritz Lennert <mlennert at club.worldonline.be> [2015-06-11 18:37:36 +0200]:
>> Hello,
>> In a python script I have the following call:
>> grass.run_command('r.series',
>> input = rate_maps,
>> output = sum_rates,
>> method = 'sum',
>> overwrite = True,
>> quiet=True)
>> rate_maps is a list which in one instance contains 8559 map names,
>> leading to an "OSError: [Errno 7] Argument list too long".
>> I know that in the shell I could use xargs to work around such a
>> problem. But how to do this in python ?
> What it the OS limit for it?
I suppose this is ARG_MAX ?
getconf ARG_MAX
2097152
A text file with all file names only uses 144551 bytes.
Or is there another limit I should look at ?
>> I could obviously loop through all maps and thus sum them individually,
>> but this just seems horribly inefficient.
>> Does anyone have a better solution ?
> - Maybe split in two or three sessions (instead of looping over all)?
Yes, thanks, I can do that. I'll also try the file option mentioned by
Anna (r.series actually has one). Didn't think of that.
Thanks to both of you !
Moritz
