[GRASS-dev] [GRASS GIS] #2694: rendering command layer and adding 3d raster layer broken
trac at osgeo.org
Thu Jun 11 18:59:09 PDT 2015
Reporter: annakrat | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.1.0
Component: wxGUI | Version: svn-trunk
Keywords: rendering | CPU: Unspecified
Platform: Linux |
Two issues I found with the new rendering with the less often used cases:
1. adding 3D raster layer breaks rendering, although there is no error,
rendering just stops working after that and busy cursors stays there. I
was trying to fix this one, but was not able to get rid of the progress
bar which was still showing up:
Index: core/render.py
--- core/render.py (revision 65443)
+++ core/render.py (working copy)
@@ -472,6 +472,8 @@
# render map layers if forced
nlayers = 0
for layer in self.layers:
+ if layer.GetType() == '3d-raster':
+ continue
if force or layer.forceRender:
nlayers += 1
layer.Render(env)
@@ -532,6 +534,8 @@
if layer.GetType() == 'overlay':
continue
+ continue
if os.path.isfile(layer.mapfile):
maps.append(layer.mapfile)
2. Rendering command layers is weird, (un)checking has no effect.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2694>
