[GRASS-dev] [GRASS GIS] #2505: v.build.polylines options aren't working
trac at osgeo.org
Fri Jun 12 01:47:48 PDT 2015
Reporter: hellik | Owner: grass-dev@…
Type: defect | Status: new
Priority: major | Milestone: 7.0.0
Component: Vector | Version: svn-releasebranch70
Resolution: | Keywords: v.build.polylines
CPU: Unspecified | Platform: All
Comment (by mlennert):
Replying to [comment:6 neteler]:
> Replying to [comment:2 neteler]:
> > Replying to [comment:1 mmetz]:
> > > Replying to [ticket:2505 hellik]:
> > > `cats=no` was indeed not working, fixed in r63321,r63322 (trunk,
relbr70).
> > Should this go also into GRASS 6?
> Still unclear.
What is actually unclear for me is what the problem was.
With a simple test line, when I comment out the line added in r63321 I get
the same results as when I leave it active, both in grass64_release and in
trunk. Both results being as expected. I have a vague memory that I could
reproduce the bug at the time, but can't remember the details.
Does someone have a more relevant test case ?
Then again, r63321 seems sufficiently non-invasive that it could probably
just be backported.
Moritz
Ticket URL: <https://trac.osgeo.org/grass/ticket/2505#comment:7>
