[GRASS-dev] GRASS GIS 7.0.1 planning: potential backports
Helmut Kudrnovsky hellik at web.de
Fri Jun 12 14:14:40 PDT 2015
Markus Neteler wrote
> On Tue, Jun 9, 2015 at 10:21 PM, Vaclav Petras <
> wenzeslaus@
> > wrote:
>> What is the status of r65057, #2626, and #2655?
> I have added it to
> https://trac.osgeo.org/grass/wiki/Grass7Planning#a7.0.1tobebackported
for r65440 in #2448 needs testing on Windows
see https://trac.osgeo.org/grass/ticket/2448#comment:23
tested locally here in a simple windows command line (outside any winGRASS
session, not in a OSGeo4W-command line):
C:\Users\xxxx>set GISBASE=C:\OSGeo4W_use\apps\grass\grass-7.0.0
C:\Users\xxxx>set
FREETYPEBASE=C:\OSGeo4W_use\bin;C:\OSGeo4W_use\apps\msys\bin;C:\OSGeo4W_use\apps\grass\grass-7.0.0\lib
C:\Users\xxxx>set PATH=%FREETYPEBASE%;%PATH%
C:\Users\xxxx>set GISRC=dummy
C:\Users\xxxx>"%GISBASE%\bin\g.mkfontcap.exe" -o
it works.
+1 for backporting
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/GRASS-GIS-7-0-1-planning-potential-backports-tp5200227p5210721.html
Sent from the Grass - Dev mailing list archive at Nabble.com.
