[GRASS-dev] r65348: Mapset's tmp dir placement and broken element search
Martin Landa
landa.martin at gmail.com
Fri Jun 12 14:30:42 PDT 2015
2015-06-11 16:59 GMT+02:00 Vaclav Petras <wenzeslaus at gmail.com>:
> Anyway, my point is that parallel calls to r.to.vect are terribly slow with
> default configuration and one must know that the solution is to change the
> attribute table backend to Postgres (or perhaps DBF where there is one
> database file per vector map AFAIK).
GRASS_VECTOR_TEMPORARY=move together with [1] could also help. Martin
[1] https://trac.osgeo.org/grass/browser/grass/trunk/lib/vector/Vlib/local_proto.h#L11
Martin Landa
http://geo.fsv.cvut.cz/gwiki/Landa
http://gismentors.cz/mentors/landa
