[GRASS-dev] [GRASS GIS] #2468: Python OSError: [Errno 7] Argument list too long when running grass.pipe_command repeatedly
GRASS GIS trac at osgeo.org
Fri Jun 12 15:09:14 PDT 2015
  Reporter:  maxnova  |      Owner:  grass-dev@…
      Type:  defect   |     Status:  closed
  Priority:  normal   |  Milestone:  6.4.5
 Component:  Python   |    Version:  6.4.4
Resolution:  fixed    |   Keywords:  OSError, pipe_command, python, script
       CPU:  x86-64   |   Platform:  Linux
Comment (by wenzeslaus):
 Replying to [comment:2 maxnova]:
 > For anyone else that runs across this issue, I've updated the
 demonstration code with the fix described above: https://gist.github.com
 /max-nova/487a82de00651a33f2c2
 Since the link to code appeared again on mailing list, it is worth noting
 that that the main issue was calling `init` function multiple times
 instead of just once (for ''initialization''). (The ticket should have
 been ideally closed as ''invalid'' or at least ''wontfix''.)
 The linked code is potentially doing same mistake, setting `GISRC`
 variable and file multiple times. If this is an actual mistake depends on
 how the code is used, but in general, it is enough to set `GISRC` just
 once and change the file content to change the Mapset.
 In some cases it is also advantageous to use `os.environ.copy()` to copy
 environment to dictionary, modify it (e.g. `env['GISRC'] = ...`) and then
 pass it as
 [https://docs.python.org/2/library/subprocess.html#subprocess.Popen env
 parameter] of a function from `grass.script.start_command()` family.
 To learn more about this topic:
  * [http://grass.osgeo.org/grass71/manuals/libpython/script.html#module-
 script.setup grass.script.setup documentation] (recently updated)
  * [http://grass.osgeo.org/grass71/manuals/grass7.html#exec-interface-
 example --exec parameter of grass command] (available in trunk, upcoming
 7.1 release, #2579)
  * user wiki:
 [http://grasswiki.osgeo.org/wiki/Working_with_GRASS_without_starting_it_explicitly
 Working with GRASS without starting it explicitly]
  * grass-dev: [http://lists.osgeo.org/pipermail/grass-
 dev/2015-June/075207.html How GRASS should behave when another session is
 already active?]
 ([http://comments.gmane.org/gmane.comp.gis.grass.devel/64536 Gmane], [http
 ://osgeo-org.1560.x6.nabble.com/How-GRASS-should-behave-when-another-
 session-is-already-active-td5208559.html Nabble])
Ticket URL: <https://trac.osgeo.org/grass/ticket/2468#comment:3>
