[GRASS-dev] All Python addons are missing
Markus Neteler
neteler at osgeo.org
Sun Jun 14 01:18:22 PDT 2015
On Jun 14, 2015 10:15 AM, "Martin Landa" <landa.martin at gmail.com> wrote:
> Hi,
> 2015-06-14 1:56 GMT+02:00 Vaclav Petras <wenzeslaus at gmail.com>:
> > Sorry to report but grass.script cannot be imported when building
addons,
> > e.g.:
> > http://grass.osgeo.org/addons/grass7/logs/d.vect.thematic2.log
> thanks for reporting, problem was broken svn repo:
> svn: Failed to add file 'setup.py': an unversioned file of the same
> name already exists
> I fixed that.
I had seen it on phone but could not fix it in the past 12hs.
> > and recently posted log for 71/trunk binary is 404:
> > http://grass.osgeo.org/grass71/binary/linux/snapshot/build.log
> No idea here, Martin
As I mentioned I generated manually that file. Then removed it to avoid
confusion with the next build. Will modify my cronjobs later today to
autogenerate the file later today.
Markus
> Martin Landa
> http://geo.fsv.cvut.cz/gwiki/Landa
> http://gismentors.cz/mentors/landa
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20150614/e47e635b/attachment.html>
