[GRASS-dev] All Python addons are missing
Markus Neteler
neteler at osgeo.org
Sun Jun 14 03:40:06 PDT 2015
On Sun, Jun 14, 2015 at 10:21 AM, Martin Landa <landa.martin at gmail.com> wrote:
> 2015-06-14 10:18 GMT+02:00 Markus Neteler <neteler at osgeo.org>:
> >> thanks for reporting, problem was broken svn repo:
> >> svn: Failed to add file 'setup.py': an unversioned file of the same
> >> name already exists
> >> I fixed that.
> to avoid confusion, addons are not built on osgeo server, but on the
> server at the CTU. Martin
Right. However, the same issue happened on the main server, now fixed.
I scheduled for later today (in 1-2 hs) the rebuild of the
binaries/manual with hopefully build.log file output. Hope the cronjob
will behave with the log redirection.
Markus
