[GRASS-dev] [GRASS GIS] #2505: v.build.polylines options aren't working
GRASS GIS trac at osgeo.org
Sun Jun 14 07:25:17 PDT 2015
  Reporter:  hellik       |      Owner:  grass-dev@…
      Type:  defect       |     Status:  new
  Priority:  major        |  Milestone:  6.4.5
 Component:  Vector       |    Version:  svn-releasebranch64
Resolution:               |   Keywords:  v.build.polylines
       CPU:  Unspecified  |   Platform:  All
Comment (by mlennert):
 Replying to [comment:10 hellik]:
 > Replying to [comment:7 mlennert]:
 > > Replying to [comment:6 neteler]:
 > > > Replying to [comment:2 neteler]:
 > > > > Replying to [comment:1 mmetz]:
 > > > > > Replying to [ticket:2505 hellik]:
 > > > > > `cats=no` was indeed not working, fixed in r63321,r63322 (trunk,
 relbr70).
 > > > > Should this go also into GRASS 6?
 > > > Still unclear.
 > > What is actually unclear for me is what the problem was.
 > as mentioned above:
 > ''cats=no was indeed not working, fixed in r63321,2 (trunk, relbr70).''
 I understand what the declared issue was and saw the fix, but what is
 weird is that using current trunk, when I undo the fix by commenting out
 the 'Vect_reset_cats(Cats);' call that was added, v.build.polyline still
 works as expected with your test data. And everything works as expected
 for me in grass64release as well, without the fix.
 So I'm not sure that the "fix" actually solved the problem.
 Moritz
Ticket URL: <https://trac.osgeo.org/grass/ticket/2505#comment:11>
