[GRASS-dev] [GRASS GIS] #2662: v.in.proj crashes on Windows (v.in.ogr problem)
trac at osgeo.org
Sun Jun 14 13:08:44 PDT 2015
Reporter: martinl | Owner: grass-dev@…
Type: defect | Status: new
Priority: blocker | Milestone: 7.0.1
Component: LibGIS | Version: svn-releasebranch70
Resolution: | Keywords: v.in.proj, r.in.proj
CPU: Unspecified | Platform: Unspecified
Comment (by hellik):
Replying to [comment:6 martinl]:
> Replying to [comment:5 hellik]:
> > any test data set?
> Just try to import data using v.in.proj to the location with different
srs...
tested with
GRASS Version: 7.1.svn
GRASS SVN revision: 65460
Build date: 2015-06-14
Build platform: i686-pc-mingw32
GDAL: 1.11.2
PROJ.4: 4.8.0
GEOS: 3.4.2
SQLite: 3.7.17
Python: 2.7.4
wxPython: 2.8.12.1
Platform: Windows-7-6.1.7601-SP1 (OSGeo4W)
C:\tmp>ogrinfo -al vienna.shp
INFO: Open of `vienna.shp'
using driver `ESRI Shapefile' successful.
Layer name: vienna
Geometry: Polygon
Feature Count: 1
Extent: (16.289482, 48.155973) - (16.463998, 48.275724)
Layer SRS WKT:
GEOGCS["GCS_WGS_1984",
DATUM["WGS_1984",
SPHEROID["WGS_84",6378137.0,298.257223563]],
PRIMEM["Greenwich",0.0],
UNIT["Degree",0.0174532925199433]]
g.proj -p
-PROJ_INFO-------------------------------------------------
proj : tmerc
datum : hermannskogel
ellps : bessel
lat_0 : 0
lon_0 : 16.33333333333333
k : 1
x_0 : 750000
y_0 : 0
no_defs : defined
towgs84 : 577.326,90.129,463.919,5.1366,1.4742,5.2970,2.4232
-PROJ_EPSG-------------------------------------------------
epsg : 31286
-PROJ_UNITS------------------------------------------------
unit : meter
units : meters
meters : 1
(Sun Jun 14 21:56:04 2015)
v.in.proj --verbose input_file=C:\tmp\vienna.shp output=vienna
extents=input
(Sun Jun 14 21:56:09 2015) Befehl ausgeführt (5 Sek)
seems to work
Helmut
p.s. any chance to get back OSGeo4W-winGRASS7.0.x-daiylies; no chance to
test here the standalone winGRASS7.0.x-daiylies
p.p.s https://trac.osgeo.org/grass/ticket/2634 is quite annyoing and makes
winGRASS-trunk quite unusable for me ...
Ticket URL: <http://trac.osgeo.org/grass/ticket/2662#comment:7>
