[GRASS-dev] how to work around "Arument list too long" error in a GRASS python script ?
Vaclav Petras
wenzeslaus at gmail.com
Mon Jun 15 05:48:00 PDT 2015
On Mon, Jun 15, 2015 at 7:41 AM, Glynn Clements <glynn at gclements.plus.com>
wrote:
> Modules which commonly use many input maps should have the option to
> read map names from a file. This mostly affects r.series, which
> already does so.
> If this issue was more common, we could consider extending G_parser()
> to allow transparently reading any option value from a file, using
> e.g. input=@filename. But that may just cause similar issues with
> --interface-description, G_recreate_command(), etc.
Good idea, although I'm afraid of potential problems with interface.
Similar solution, with similar potential issues, is to create automatically
`input_file` when `input` is multiple or when specified in code. Moving
things to parser is definitively more advantageous for things like
overwrite but it may cause some code and reading duplication for Python
scripts.
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20150615/abf21cf9/attachment.html>
