[GRASS-dev] [GRASS GIS] #2634: 'utf8' codec can't decode byte 0xf6 in position 8: invalid start byte
GRASS GIS trac at osgeo.org
Tue Jun 16 01:21:54 PDT 2015
  Reporter:  hellik    |      Owner:  grass-dev@…
      Type:  defect    |     Status:  new
  Priority:  critical  |  Milestone:  7.0.1
 Component:  Default   |    Version:  svn-trunk
Resolution:            |   Keywords:  utf, wxgui
       CPU:  x86-32    |   Platform:  MSWindows 7
Comment (by hellik):
 it's also now in the 7.0.1RC1, tested in the NC sample dataset
 System Info
 GRASS Version: 7.0.1RC1
 GRASS SVN Revision: 65472
 Erstellungsdatum: 2015-06-15
 Build Platform: i686-pc-mingw32
 GDAL/OGR: 1.11.2
 PROJ.4: 4.8.0
 GEOS: 3.4.2
 SQLite: 3.7.17
 Python: 2.7.4
 wxPython: 2.8.12.1
 Platform: Windows-7-6.1.7601-SP1 (OSGeo4W)
 choosing d.rast from the wxgui
 a MS error box pops up with
 followed by this message in the wxgui
   File "C:\OSGEO4~2\apps\grass\grass-7.0.1RC1\gui\wxpython\g
 ui_core\forms.py", line 2023, in OnUpdateDialog
 self.parent.updateValuesHook()
 ui_core\forms.py", line 628, in updateValuesHook
 self.SetStatusText('
 '.join(self.notebookpanel.createCmd(ignoreErrors = True)))
 TypeError
 as mentioned in the original ticket above, e.g. g.region works without any
 problem
 any ideas?
Ticket URL: <https://trac.osgeo.org/grass/ticket/2634#comment:5>
