[GRASS-dev] [GRASS GIS] #2696: Set language in GRASS-7.0.0
trac at osgeo.org
Tue Jun 16 02:09:54 PDT 2015
Reporter: Biz | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.1
Component: Default | Version: 7.0.0
Resolution: | Keywords: Set language
CPU: Unspecified | Platform: MSWindows 7
Comment (by marisn):
In meantime you could try to edit manually wx settings file. It should be
located in your user home folder, appdata/grass version/wx (those are
hidden folders - just search around for proper folder name, file is called
"wx").
Open that wx file with an text editor (notepad), find line starting with
"language" and replace it with:
language;locale;lc_all;C
Report back success or failure.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2696#comment:1>
