[GRASS-dev] [GRASS GIS] #2304: Problems with add category to all features workflow
trac at osgeo.org
Tue Jun 16 03:29:35 PDT 2015
Reporter: wenzeslaus | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.1.0
Component: Default | Version: unspecified
Resolution: | Keywords: v.edit, v.category
CPU: Unspecified | Platform: Unspecified
Comment (by mlennert):
Replying to [comment:5 wenzeslaus]:
> Unresolved:
> * `v.category` has a parameter/option option while `v.edit` has a
parameter tool
The two modules do different things and I don't really see it as a problem
that the parameters have different names.
> * `v.category` builds topology when there was no change
v.category only does this when there is an output map and for any new map
topology has to be built, so again, I don't see this as a problem.
> * `v.category` does nothing for `option=step`; using `option=sum` under
the same conditions gives a result if there is something else to add, it
is not in the example in manual
There is no option=step. step is a separate parameter which allows to
change the default step of 1 when v.category creates new cat values.
> * v.category says 0 features modified. when it finished report or print
but it seems redundant I wouldn't expect something else when using report
or print and not providing output
I cannot reproduce this.
> * in GUI query tool, you will see that it shows only one layer and one
category
> * now I see that layers are there but they are represented as separate
maps which is not what I would expect since (layers are "inside" the map);
I missed that before because I was querying more than one map and I
considered the other (folded) row as one of the other maps
> * this needs separate ticket
IMHO this behavior is debatable, but definitely not a bug.
I again suggest closing this bug, as there is no actual bug report in
here.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2304#comment:6>
