[GRASS-dev] [GRASS GIS] #2699: g.gui.iclass doesn't run after selecting training areas
trac at osgeo.org
Fri Jun 19 00:23:35 PDT 2015
Reporter: ThayseNery | Owner: grass-dev@…
Type: defect | Status: new
Priority: major | Milestone: 7.0.1
Component: wxGUI | Version: 7.0.0
Resolution: | Keywords: g.gui.iclass
CPU: x86-64 | Platform: MSWindows 7
Changes (by martinl):
* keywords: => g.gui.iclass
* component: Default => wxGUI
Old description:
> Hi,
> I have been trying to apply supervised classification using
> '''g.gui.iclass''' in GRASS GIS 7.0.1RC1 windows but it doesn't work
> properly. What I do:
> 1) Launch g.gui.iclass
> I can open the module by selecting group and imagery subgroup. But when
> the windows GRASS Supervised Classification Tool opens, I observed that
> name of imagery subgroup is missing. By adding it through select imagery
> group I got the following error:
> ''File "C:\Program Files (x86)\GRASS GIS
> 7.0.1RC1\gui\wxpython\iclass\toolbars.py", line 163, in <lambda>
> lambda event : self.parent.AddBands()),
> 7.0.1RC1\gui\wxpython\iclass\frame.py", line 513, in AddBands
> subgroup=self.g['subgroup'])
> 7.0.1RC1\etc\python\grass\pydispatch\signal.py", line 229, in emit
> dispatcher.send(signal=self, *args, **kwargs)
> 7.0.1RC1\etc\python\grass\pydispatch\dispatcher.py", line 349, in send
> **named
> 7.0.1RC1\etc\python\grass\pydispatch\robustapply.py", line 60, in
> robustApply
> return receiver(*arguments, **named)
> 7.0.1RC1\gui\wxpython\iscatt\controllers.py", line 1111, in GroupSet
> self.scatt_mgr.SetBands(bands)
> 7.0.1RC1\gui\wxpython\iscatt\controllers.py", line 164, in SetBands
> i = GetRasterInfo(b)
> 7.0.1RC1\gui\wxpython\iscatt\iscatt_core.py", line 832, in GetRasterInfo
> raise GException("r.info failed:\n%s" % msg)
> core.gcmd.GException: r.info failed:
> Illegal filename <PERMANENT
> >. Character not allowed.''
> My file name doesn’t have any special character as it is called feb2014.
> Although the imagery subgroup cannot been opened, I am able to:
> 2) Add RGB map layer
> 3) Add a class in the class manager and assign a custom color
> 5) I can digitize new area
> But After selecting some training areas, I try to run the model and I got
> another error:
> 7.0.1RC1\gui\wxpython\iclass\frame.py", line 911, in OnRunAnalysis
> if self.RunAnalysis():
> 7.0.1RC1\gui\wxpython\iclass\frame.py", line 922, in RunAnalysis
> if not self.CheckInput(group = self.g['group'], vector =
> self.trainingAreaVector):
> 7.0.1RC1\gui\wxpython\iclass\frame.py", line 1087, in CheckInput
> rasterInfo = grass.raster_info(groupLayers[0])
> 7.0.1RC1\etc\python\grass\script\raster.py", line 70, in raster_info
> s = read_command('r.info', flags='gre', map=map)
> 7.0.1RC1\etc\python\grass\script\core.py", line 427, in read_command
> return handle_errors(returncode, stdout, args, kwargs)
> 7.0.1RC1\etc\python\grass\script\core.py", line 312, in handle_errors
> returncode=returncode)
> grass.exceptions.CalledModuleError: Module run None ['r.info', '-gre',
> u'map=Feb2014_111_112_753mos at PERMANENT\r'] ended with error
> Process ended with non-zero return code 1. See errors in the (error)
> output.''
> I have been trying to work with this module for a week and I cannot
> figure out why it doesn’t work.
> Many thanks in advance for any help.
New description:
**named
robustApply
another error:
output.''
I have been trying to work with this module for a week and I cannot figure
Ticket URL: <https://trac.osgeo.org/grass/ticket/2699#comment:1>
