[GRASS-dev] [GRASS GIS] #2699: g.gui.iclass doesn't run after selecting training areas
GRASS GIS trac at osgeo.org
Fri Jun 19 05:37:30 PDT 2015
  Reporter:  ThayseNery  |      Owner:  grass-dev@…
      Type:  defect      |     Status:  new
  Priority:  major       |  Milestone:  7.0.1
 Component:  wxGUI       |    Version:  7.0.0
Resolution:              |   Keywords:  g.gui.iclass
       CPU:  x86-64      |   Platform:  MSWindows 7
Comment (by annakrat):
 Thank you for the extensive description. I can confirm this problem on
 Windows 8, however it works on my Ubuntu laptop.
 If you need to do it on Windows, you could try for now less interactive
 way - using vector digitizer to digitize training areas (which you
 probably already have), rasterize it (v.to.rast) and generate signature
 file using i.gensig.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2699#comment:3>
