[GRASS-dev] Weekly snapshot - link with non-changing name?
Rainer M Krug
Rainer at krugs.de
Mon Jun 22 06:40:21 PDT 2015
Markus Neteler <neteler at osgeo.org> writes:
> On Jun 20, 2015 5:16 PM, "Rainer M Krug" <Rainer at krugs.de> wrote:
>> Vaclav Petras <wenzeslaus at gmail.com> writes:
>> It is really just a automatic snapshot, not a tested
>> > release.
>> Thanks - so I will then use HEAD of the svn - easier to do in homebrew,
>> as no sha hash is needed of the downloaded file.
> You want me to generate that?
No - no need. I just tell homebrew to download head from svn and than to
compile it - it works.
I will post a link to the recipe later this week. This will make testing
of GRASS 7.1 easy on OS X.
Thanks a lot,
Rainer
> Markus
>> Thanks,
>> Rainer
>> > Vaclav
>> > Thanks,
>> >> Rainer
>> >> > Rainer
>> >> >> Markus
>> >> Rainer M. Krug
>> >> email: Rainer<at>krugs<dot>de
>> >> PGP: 0x0F52F982
>> >> _______________________________________________
>> >> grass-dev mailing list
>> >> grass-dev at lists.osgeo.org
>> >> http://lists.osgeo.org/mailman/listinfo/grass-dev
>> Rainer M. Krug
>> PGP: 0x0F52F982
Rainer M. Krug
PGP: 0x0F52F982
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20150622/d6cdcc4d/attachment.pgp>
