[GRASS-dev] [GRASS-user] Error in pansharp tool: missing grass.script
Nikos Alexandris nik at nikosalexandris.net
Thu Jun 25 08:38:38 PDT 2015
* Vaclav Petras <wenzeslaus at gmail.com> [2015-06-25 09:58:47 -0400]:
> On Thu, Jun 25, 2015 at 3:41 AM, Moritz Lennert <
> mlennert at club.worldonline.be> wrote:
> > On 24/06/15 15:09, Vaclav Petras wrote:
> >> It seems like one. I think it might help, at least help to debug, if you
> >> replace "import grass.script as grass" by "import grass.script as
> >> gscript" and "grass." by "gscript.". I think this change should be done
> >> anyway in all source code.
> > Could you explain your reasoning behind this ? IMHO, it should not make
> > any difference whether you use grass or gscript as the alias.
> Sure. First of all, this just look strange by default I believe:
> import aaa.bbb as aaa
> Why not
> import aaa.bbb
> or often appropriate
> import aaa.bbb as bbb
> or (my favorite)
> import aaa.bbb as ab
> or simple
> import aaa
> Alias shouldn't create confusion which I think it creates.
> After
> which of the following will work?
> from grass import run_commad
> from grass import pygrass
> The second line will work although in the following case it is the first
> line.
> grass.run_command
> grass.pygrass
> Sure, this is just how Python interprets the import statements, so if you
> know it, you are fine, but why should we make reading of the source code
> harder then necessary?
I prefer self-explained names in general.  Why make it hard to read the
code, for anyone who cares, anyway?
At this point I'd like too to stress the need for proper commenting and
documenting source code.  Many, if not most, scripts, are not easy to
read. There are simply too many short and not self-explained variable names,
and undocumented functions as well.
This is yet another bold ToDo in my list, at least for add-ons, once I
will have again the freedom and time to contribute.
> The current situation leads to cases like:
> >>> grass.run_command
> <function run_command at 0x7f185ed61500>
> Fine.
> >>> grass.script.run_command
> Traceback (most recent call last):
>  File "<stdin>", line 1, in <module>
> AttributeError: 'module' object has no attribute 'script'
> OK. We haven't imported grass.script in the proper way, so let's do it.
> >>> import grass.script
> Works.
> >>> grass.run_command
> AttributeError: 'module' object has no attribute 'run_command'
> Does not work anymore.
Yep, but a scripter wouldn't want to repeat `grass.script.` everytime.
Would he?  I do agree with Vaclav, however, with a convention that is
not confusing.  And, at the same time, it is still practical.
Please, think of "inviting" new scripters with code that is easy and a
joy to study.
Nikos
> I think that broadly used
> is just a legacy from the first version of Python API where "grass.script"
> was the only package and thus it was just `grass`. Then new (sub-)packages
> were introduced, probably "grass.lib" which forced the former `grass` to be
> renamed/moved to `grass.script`. To avoid changing all calls of functions
> from `grass.run_command` to something else, `grass.script` was imported
> with alias `grass`. This then spread into new and user code because the
> code is (or hopefully was) the only documentation. The unfortunate part is
> that this was some very first version of the API which was never released
> as stable (official introduction of Python API is 7.0.0, it was just
> experimental and internal in 6.4) but it influenced the common practice
> which I think is not the best practice. At least, this is how I understand
> it.
> I don't see a reason why to keep it when there is a better practice
> available. We should especially change it in GUI and parser's --script. I
> believe none of them are change of the API, so it can be done anytime. The
> code itself should be changed too, we are doing a lot of other non-crucial
> changes anyway. The benefit is better code as an example for users and
> easier maintenance because it is just more clear.
> Well, that's what I think.
> Vaclav
