[GRASS-dev] [GRASS-user] Error in pansharp tool: missing grass.script
Moritz Lennert
mlennert at club.worldonline.be
Fri Jun 26 01:27:15 PDT 2015
On 25/06/15 15:58, Vaclav Petras wrote:
> On Thu, Jun 25, 2015 at 3:41 AM, Moritz Lennert
> <mlennert at club.worldonline.be <mailto:mlennert at club.worldonline.be>> wrote:
> On 24/06/15 15:09, Vaclav Petras wrote:
> It seems like one. I think it might help, at least help to
> debug, if you
> replace "import grass.script as grass" by "import grass.script as
> gscript" and "grass." by "gscript.". I think this change should
> be done
> anyway in all source code.
> Could you explain your reasoning behind this ? IMHO, it should not
> make any difference whether you use grass or gscript as the alias.
> Sure. First of all, this just look strange by default I believe:
> import aaa.bbb as aaa
> Why not
> import aaa.bbb
> or often appropriate
> import aaa.bbb as bbb
> or (my favorite)
> import aaa.bbb as ab
> or simple
> import aaa
> Alias shouldn't create confusion which I think it creates.
> After
> which of the following will work?
> from grass import run_commad
> from grass import pygrass
> The second line will work although in the following case it is the first
> line.
> grass.run_command
> grass.pygrass
> Sure, this is just how Python interprets the import statements, so if
> you know it, you are fine, but why should we make reading of the source
> code harder then necessary?
> The current situation leads to cases like:
> >>> grass.run_command
> <function run_command at 0x7f185ed61500>
> Fine.
> >>> grass.script.run_command
> Traceback (most recent call last):
> File "<stdin>", line 1, in <module>
> AttributeError: 'module' object has no attribute 'script'
> OK. We haven't imported grass.script in the proper way, so let's do it.
> >>> import grass.script
> Works.
> >>> grass.run_command
> AttributeError: 'module' object has no attribute 'run_command'
> Does not work anymore.
> I think that broadly used
> is just a legacy from the first version of Python API where
> "grass.script" was the only package and thus it was just `grass`. Then
> new (sub-)packages were introduced, probably "grass.lib" which forced
> the former `grass` to be renamed/moved to `grass.script`. To avoid
> changing all calls of functions from `grass.run_command` to something
> else, `grass.script` was imported with alias `grass`. This then spread
> into new and user code because the code is (or hopefully was) the only
> documentation. The unfortunate part is that this was some very first
> version of the API which was never released as stable (official
> introduction of Python API is 7.0.0, it was just experimental and
> internal in 6.4) but it influenced the common practice which I think is
> not the best practice. At least, this is how I understand it.
> I don't see a reason why to keep it when there is a better practice
> available. We should especially change it in GUI and parser's --script.
> I believe none of them are change of the API, so it can be done anytime.
> The code itself should be changed too, we are doing a lot of other
> non-crucial changes anyway. The benefit is better code as an example for
> users and easier maintenance because it is just more clear.
> Well, that's what I think.
Thanks for that detailed explanation. Although I don't feel as strongly
about this as you seem to (probably because my scripts are never that
complex), I understand your point and I agree that i) we should have a
unified way of doing it and ii) using your gscript (or something
similar) is probably better than the current grass.
Moritz
