[GRASS-dev] G7.0.svn: g.remove segfault
Sören Gebbert soerengebbert at googlemail.com
Fri Jun 26 11:37:01 PDT 2015
may i suggest a patch to solve this issue?
http://pastebin.com/D8yautBh
Best regards
Soeren
2015-06-26 20:27 GMT+02:00 Sören Gebbert <soerengebbert at googlemail.com>:
> Hi,
> here a traceback of a g.remove segfault that happens while testing
> temporal modules:
> http://pastebin.com/LDVKgEed
> Seems to be in M_do_remove calling some sort of sprintf?? Maybe line
> 102, since the colr2 buffer is only 50 chars in length ... however,
> sprintf() function shouldn't be used at all.
> Best regards
> Soeren
> 2015-06-26 16:11 GMT+02:00 Vaclav Petras <wenzeslaus at gmail.com>:
>> On Fri, Jun 26, 2015 at 6:09 AM, Maris Nartiss <maris.gis at gmail.com> wrote:
>>> I can not repeat the issue with current trunk on ~AMD64 Gentoo.
>>> Please provide locale information; run g.remove under valgrind to see
>>> the source of memory corruption.
>> That's the hard part. I cannot run valgrind easily. I'm not getting the
>> error when I execute it manually (at least not often enough). It is
>> happening only with some part of tests for me. As I've written before, I
>> originally haven't reported it at all because I'm getting with one copy of
>> GRASS but not with the other on the same machine without being able to find
>> any difference in between them. (Fortunately the copy which works is the one
>> running the automated tests.) Only after Soeren and now Markus reported the
>> same, I started to lean towards opinion that it is not a local issue.
>> As for valgrind, that's unfortunately a feature request for gunittest. Which
>> is even more advanced then I expected because valgrind is not need for the
>> tested module but just for a helper one, anyway, the testing framework
>> should allow that.
>> I'm not sure if Soeren can repeat it in more direct way.
>>> Māris.
>>> 2015-06-25 3:47 GMT+03:00 Vaclav Petras <wenzeslaus at gmail.com>:
>>> > On Wed, Jun 24, 2015 at 9:29 AM, Vaclav Petras <wenzeslaus at gmail.com>
>>> > wrote:
>>> >> On Wed, Jun 24, 2015 at 3:12 AM, Markus Neteler <neteler at osgeo.org>
>>> >> wrote:
>>> >>> On Wed, Jun 24, 2015 at 9:06 AM, Markus Neteler <neteler at osgeo.org>
>>> >>> wrote:
>>> >>> > Hi,
>>> >>> > to my surprise I managed to generate a segfault using g.remove:
>>> >>> please disregard. Apparently a system update triggered this (no idea
>>> >>> how).
>>> >>> "make distclean" helped.
>>> >> Well, you are not the only one with the problem:
>>> >> https://lists.osgeo.org/pipermail/grass-dev/2015-May/075083.html
>>> >> I will have to try distclean, although I think I tried it several times
>>> >> before.
>>> > I'm getting the same issues again. Now I actually see a buffer overflow:
>>> > *** buffer overflow detected ***: g.remove terminated
>>> > ======= Backtrace: =========
>>> > /lib/x86_64-linux-gnu/libc.so.6(+0x7338f)[0x7fc697b2b38f]
>>> > /lib/x86_64-linux-gnu/libc.so.6(__fortify_fail+0x5c)[0x7fc697bc2c9c]
>>> > /lib/x86_64-linux-gnu/libc.so.6(+0x109b60)[0x7fc697bc1b60]
>>> > /lib/x86_64-linux-gnu/libc.so.6(+0x109069)[0x7fc697bc1069]
>>> > /lib/x86_64-linux-gnu/libc.so.6(_IO_default_xsputn+0xbc)[0x7fc697b3370c]
>>> > /lib/x86_64-linux-gnu/libc.so.6(_IO_vfprintf+0x26b0)[0x7fc697b043a0]
>>> > /lib/x86_64-linux-gnu/libc.so.6(__vsprintf_chk+0x84)[0x7fc697bc10f4]
>>> > /lib/x86_64-linux-gnu/libc.so.6(__sprintf_chk+0x7d)[0x7fc697bc104d]
>>> > /home/vpetras/dev/grass/trunk/dist.x86_64-unknown-linux-gnu/lib/libgrass_manage.7.1.svn.so(M_do_remove+0
>>> > x2e8)[0x7fc6982e9148]
>>> > g.remove(main+0x68d)[0x401c5d]
>>> > /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xf5)[0x7fc697ad9ec5]
>>> > g.remove[0x401e3e]
>>> > ======= Memory map: ========
>>> > 00400000-00403000 r-xp 00000000 08:11 16127189
>>> > ist.x86_64-unknown-linux-gnu/bin/g.remove
>>> > 00602000-00603000 r--p 00002000 08:11 16127189
>>> > 00603000-00604000 rw-p 00003000 08:11 16127189
>>> > It fails with a lot of tests but with many other it works. I'm not sure
>>> > if
>>> > all errors are stack overflow but I could catch all output the a fine
>>> > next
>>> > time.
>>> > Vaclav
>>> > _______________________________________________
>>> > grass-dev mailing list
>>> > grass-dev at lists.osgeo.org
>>> > http://lists.osgeo.org/mailman/listinfo/grass-dev
