[GRASS-dev] table with the parser standard options
Pietro
peter.zamb at gmail.com
Tue Jun 30 21:42:14 PDT 2015
Dear devs,
I was not able to find a table in the GRASS manual pages with a
summary of all the default options as define in
parser_standard_options.c (lib/gis/parser_standard_options.c).
Therefore I wrote a python command line tool to extract them from the
source and print/write to a file in CSV/HTML format.
Probably I should use regexp but I'm not good with them...
The command line tool is attached.
Some usage example are:
$ python2 options.py -t lib/gis/parser_standard_options.c -f csv -o
stadard_options.csv
The command line should be able also to download the source file
directly from a link but it works only partially.
I believe we should add the generated table somewhere in the manual docs.
Should I add this python script to grass_addons/tools?
What do you think?
Pietro
Type: application/octet-stream
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20150701/238c0fd4/attachment.obj>
