[GRASS-dev] [GRASS GIS] #2605: d.rast.leg: invalid literal for float(): rectangle
GRASS GIS trac at osgeo.org
Sun Mar 1 15:05:31 PST 2015
 Reporter:  pertusus     |       Owner:  grass-dev@…
     Type:  defect       |      Status:  new
 Priority:  normal       |   Milestone:  7.0.1
Component:  Display      |     Version:  svn-releasebranch70
 Keywords:               |    Platform:  Unspecified
      Cpu:  Unspecified  |
 I get a traceback for d.rast.leg.
 d.rast.leg raster_selection_basins_change lines=2
   File "/usr/local/grass-7.0.0svn//scripts/d.rast.leg", line 167, in
 <module>
     main()
   File "/usr/local/grass-7.0.0svn//scripts/d.rast.leg", line 103, in main
     f = tuple([float(x) for x in s.split()[1:5]])
 ValueError: invalid literal for float(): rectangle:
 This is triggered by a wrong parsing of d.info which returns:
 frame rectangle: 0.000000 640.000000 0.000000 480.000000
 Original code is
 which naturally the to x being 'rectangle:'
 I attach a patch where I propose instead:
  [float(x) for x in s.split(":")[1].split()[0:4]]
 It seems more robust, though I don't know if the : will be there forever.
 Overall, the approach is not very robust, but I have no idea on what's
 going on so I only propose that fix which may not be appropriate in other
 cases.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2605>
