[GRASS-dev] Select vector feature - Error
Margherita Di Leo diregola at gmail.com
Mon Mar 2 02:28:08 PST 2015
when i try to select a feature with the "select vector feature" button from
map display, I get an Error pop up that reads:
Error occured during calling of handler: _onMapClickHandler
Handler was unregistered.
Reason: VectorSelectBase instance has no attribute 'map'
  File "/usr/local/grass-7.1.svn/gui/wxpython/mapwin/base.py", line 191, in
HandlersCaller
    handler(event)
  File "/usr/local/grass-7.1.svn/gui/wxpython/gui_core/vselect.py", line
187, in _onMapClickHandler
    vWhatDic = self.QuerySelectedMap()
272, in QuerySelectedMap
    message=_("Failed to query vector map(s) <%s>.") % self.map)
AttributeError: VectorSelectBase instance has no attribute 'map'
Thanks
Best regards,
Dr. Margherita DI LEO
Scientific / technical project officer
European Commission - DG JRC
Institute for Environment and Sustainability (IES)
Via Fermi, 2749
I-21027 Ispra (VA) - Italy - TP 261
Tel. +39 0332 78 3600
margherita.di-leo at jrc.ec.europa.eu
Disclaimer: The views expressed are purely those of the writer and may not
in any circumstance be regarded as stating an official position of the
European Commission.
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20150302/c05fde61/attachment-0001.html>
