[GRASS-dev] [GRASS GIS] #2613: Polygons disappear after v.overlay AND operation
trac at osgeo.org
Fri Mar 6 01:36:45 PST 2015
Reporter: dido | Owner: grass-dev@…
Type: defect | Status: new
Priority: major | Milestone:
Component: Vector | Version: 7.0.0
Keywords: v.overlay and polygons damaged | Platform: MSWindows 7
Cpu: x86-64 |
A shapefile polygon set A has been cut using a grid polygon B using a
v.overlay AND operation. The result is expected to contain all the A
polygons that are enclosed within the grid polygon B.
The output is almost as expected but several A polygons within the B
rectangle are missing. GRASS version is 7.0.0.RC1. Here is the io console
log:
(Fri Mar 06 11:07:12 2015)
v.overlay ainput=K3445_NEW_FISH at BGM_POLY_UTM
binput=GRID_K34058 at BGM_POLY_UTM operator=and output=K34058_NEW
Copying vector features from <K3445_NEW_FISH at BGM_POLY_UTM>...
Copying vector features from <GRID_K34058 at BGM_POLY_UTM>...
Snapping boundaries with 1e-008 ...
Breaking lines...
Removing duplicates...
Cleaning boundaries at nodes...
Breaking lines...
Breaking lines...
WARNING: Number of incorrect boundaries: 949
Merging lines...
Attaching islands...
Building areas...
25262 areas built
7375 isles built
Number of nodes: 41280
Number of primitives: 60697
Number of points: 0
Number of lines: 0
Number of boundaries: 60697
Number of centroids: 0
Number of areas: 25262
Number of isles: 7375
Querying vector map <K3445_NEW_FISH at BGM_POLY_UTM>...
Querying vector map <GRID_K34058 at BGM_POLY_UTM>...
Writing centroids...
WARNING: Unable to delete file
'E:\mapping\GRASS7DB/BGM_POLY_UTM/BGM_POLY_UTM/.tmp/unknown/vector/tmp_7316/coor'
Building topology for vector map <K34058_NEW at BGM_POLY_UTM>...
Registering primitives...
42630 primitives registered
642388 vertices registered
Building areas...
12823 areas built
2888 isles built
Attaching centroids...
Number of nodes: 19873
Number of primitives: 42630
Number of points: 0
Number of lines: 0
Number of boundaries: 29808
Number of centroids: 12822
Number of areas: 12823
Number of isles: 2888
v.overlay complete.
(Fri Mar 06 11:07:46 2015) Command finished (34 sec)
Files can be provided upon request (~50 Mb).
Ticket URL: <http://trac.osgeo.org/grass/ticket/2613>
