[GRASS-dev] [GRASS GIS] #2613: Polygons disappear after v.overlay AND operation
trac at osgeo.org
Fri Mar 6 06:30:17 PST 2015
Reporter: dido | Owner: grass-dev@…
Type: defect | Status: closed
Priority: major | Milestone:
Component: Vector | Version: 7.0.0
Resolution: fixed | Keywords: v.overlay and polygons damaged
Platform: MSWindows 7 | Cpu: x86-64
Changes (by martinl):
* status: new => closed
* resolution: => fixed
Old description:
> A shapefile polygon set A has been cut using a grid polygon B using a
> v.overlay AND operation. The result is expected to contain all the A
> polygons that are enclosed within the grid polygon B.
> The output is almost as expected but several A polygons within the B
> rectangle are missing. GRASS version is 7.0.0.RC1. Here is the io console
> log:
> (Fri Mar 06 11:07:12 2015)
> v.overlay ainput=K3445_NEW_FISH at BGM_POLY_UTM
> binput=GRID_K34058 at BGM_POLY_UTM operator=and output=K34058_NEW
> Copying vector features from <K3445_NEW_FISH at BGM_POLY_UTM>...
> Copying vector features from <GRID_K34058 at BGM_POLY_UTM>...
> Snapping boundaries with 1e-008 ...
> Breaking lines...
> Removing duplicates...
> Cleaning boundaries at nodes...
> Breaking lines...
> Breaking lines...
> WARNING: Number of incorrect boundaries: 949
> Merging lines...
> Attaching islands...
> Building areas...
> 25262 areas built
> 7375 isles built
> Number of nodes: 41280
> Number of primitives: 60697
> Number of points: 0
> Number of lines: 0
> Number of boundaries: 60697
> Number of centroids: 0
> Number of areas: 25262
> Number of isles: 7375
> Querying vector map <K3445_NEW_FISH at BGM_POLY_UTM>...
> Querying vector map <GRID_K34058 at BGM_POLY_UTM>...
> Writing centroids...
> WARNING: Unable to delete file
> 'E:\mapping\GRASS7DB/BGM_POLY_UTM/BGM_POLY_UTM/.tmp/unknown/vector/tmp_7316/coor'
> Building topology for vector map <K34058_NEW at BGM_POLY_UTM>...
> Registering primitives...
> 42630 primitives registered
> 642388 vertices registered
> Building areas...
> 12823 areas built
> 2888 isles built
> Attaching centroids...
> Number of nodes: 19873
> Number of primitives: 42630
> Number of points: 0
> Number of lines: 0
> Number of boundaries: 29808
> Number of centroids: 12822
> Number of areas: 12823
> Number of isles: 2888
> v.overlay complete.
> (Fri Mar 06 11:07:46 2015) Command finished (34 sec)
> Files can be provided upon request (~50 Mb).
New description:
log:
Breaking lines...
Breaking lines...
Breaking lines...
Merging lines...
Building areas...
25262 areas built
7375 isles built
Number of points: 0
Number of lines: 0
Building areas...
12823 areas built
2888 isles built
Number of points: 0
Number of lines: 0
v.overlay complete.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2613#comment:3>
