[GRASS-dev] [GRASS GIS] #2617: wxgui Raster query redirect to console UnicodeDecodeError
trac at osgeo.org
Mon Mar 9 11:19:31 PDT 2015
Reporter: marisn | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.1
Component: wxGUI | Version: svn-trunk
Keywords: query, encoding | Platform: MSWindows Vista
Cpu: Unspecified |
Comment(by marisn):
No, this is not a solution - it is still broken.
I appended a following print in query.py L185:
print 'k: %s (%s) v: %s (%s)' % (k, type(k), v, type(v))
And here is output:
k: east, north (<type 'unicode'>) v: 622578.672986, 6399325.43444 (<type
'str'>)
k: dores_idw at kalistrats (<type 'unicode'>) v: {'nosaukums': '',
'kr\xc4\x81sa': '255:202:000', 'v\xc4\x93rt\xc4\xabba':
'71.6390742964988'} (<type 'dict'>)
k: nosaukums (<type 'str'>) v: (<type 'str'>)
k: krāsa (<type 'str'>) v: 255:202:000 (<type 'str'>)
File "C:\Program Files\GRASS GIS
7.1.svn\gui\wxpython\mapwin\buffered.py", line 1230, in
MouseActions
self.OnLeftUp(event)
7.1.svn\gui\wxpython\mapwin\buffered.py", line 1407, in
OnLeftUp
self.mapQueried.emit(x=self.mouse['end'][0],
y=self.mouse['end'][1])
7.1.svn\etc\python\grass\pydispatch\signal.py", line 229, in
emit
dispatcher.send(signal=self, *args, **kwargs)
7.1.svn\etc\python\grass\pydispatch\dispatcher.py", line
349, in send
**named
7.1.svn\etc\python\grass\pydispatch\robustapply.py", line
60, in robustApply
return receiver(*arguments, **named)
7.1.svn\gui\wxpython\mapdisp\frame.py", line 868, in Query
self.QueryMap(east, north, qdist, rast, vect)
7.1.svn\gui\wxpython\mapdisp\frame.py", line 922, in
QueryMap
self.dialogs['query'] = QueryDialog(parent = self, data =
result)
7.1.svn\gui\wxpython\gui_core\query.py", line 46, in
__init__
self._model = QueryTreeBuilder(self.data,
column=self._colNames[1])
7.1.svn\gui\wxpython\gui_core\query.py", line 201, in
QueryTreeBuilder
addNode(parent=model.root, data=part, model=model)
7.1.svn\gui\wxpython\gui_core\query.py", line 190, in
addNode
addNode(parent=node, data=v, model=model)
7.1.svn\gui\wxpython\gui_core\query.py", line 187, in
addNode
k = DecodeString(k)
7.1.svn\gui\wxpython\core\gcmd.py", line 76, in DecodeString
return string.decode(_enc)
7.1.svn\Python27\lib\encodings\cp1257.py", line 15, in
decode
return codecs.charmap_decode(input,errors,decoding_table)
UnicodeDecodeError
'charmap' codec can't decode byte 0x81 in position 3:
character maps to <undefined>
As it is visible from the output, on the second line v contains UTF-8
encoded text. Lines 3 and 4 report it to be a str and thus a DecodeString
is called. So far - nothing bad, but there kicks in DecodeString - it is
using GetSystemEncoding to decode string. On this system _enc variable is
set to cp1257 - this is definitely not UTF-8 and thus decoding fails.
The string in question (krāsa) is coming form the GRASS translation to
Latvian language - to reproduce the issue on your system, you must
translate "color" to a word with non-ascii letters in it (zbarvenã) and,
of course, encode translation file (PO) as UTF-8.
The source of problem is r47310 where instead of installing unicode
version of gettext a bytestring version is installed. This should work
fine, but now in every place where a _() call is made, it returns str for
unicode translations. Reverting r47310 fixes this bug (and probably others
too!) without any problems, still I would like to hear Glynn's rationale
why it was necessary in the first place (preferably with patches that
solve _() issue if r47310 is to stay). Not using unicode version of
gettext is really strange, as Slovenian is the only language NOT using
UTF-8 in their PO files and it has seen the last update in 2005, thus
GRASS PO files ARE unicode-ready.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2617#comment:2>
