[GRASS-dev] [GRASS GIS] #2618: v.vector option=transfer does not copy multiple cat values
GRASS GIS trac at osgeo.org
Mon Mar 9 11:33:34 PDT 2015
 Reporter:  ulf                  |       Owner:  grass-dev@…
     Type:  defect               |      Status:  new
 Priority:  normal               |   Milestone:  7.0.1
Component:  Vector               |     Version:  7.0.0
 Keywords:  v.category transfer  |    Platform:  Linux
      Cpu:  x86-64               |
Comment(by ulf):
 One row disappeared from my example - to create map {{{test2}}} i did the
 following:
 echo "100|100|1" | v.in.ascii output=test input=-
 fid=$(v.edit --quiet layer=1 map=test tool=select cat=1)
 v.edit map=test layer=1 tool=catadd ids=${fid} cats=2
 v.category option=transfer layer=1,2 input=test output=test2
 Sorry about that,
 Ulf
Ticket URL: <http://trac.osgeo.org/grass/ticket/2618#comment:1>
