[GRASS-dev] "Complete basic cartography suite in GRASS GIS wxGUI Map Display"
Dp Docs sdpan21 at gmail.com
Mon Mar 9 14:59:54 PDT 2015
Durgesh Pandey.
On Tue, Mar 10, 2015 at 3:24 AM, Vaclav Petras <wenzeslaus at gmail.com> wrote:
> On Mon, Mar 9, 2015 at 5:38 PM, Dp Docs <sdpan21 at gmail.com> wrote:
>> Sir, I am getting one problem while accessing the subversion repo. Can
>> you please help me with this?
> I don't know why svn says "Connection refused". checkout works for me now.
> Aren't you behind some firewall? Do other Subversion repositories work for
> you (e.g. from Source Forge and GitHub)?
​Ok. It's Not working any one of them. I think there are some blocked ports
from proxy. First I will need to handle with it.​
>> the problem is attached in this email.
> Please, if you have error messages which are short text, just include the
> text in the email. Only if you have something which cannot be copy-pasted,
> or saved to a plain text file, use screenshots. For screenshots, create
> them as small as possible and include file extension to the file name.
​I will do it from  next time. ​
> Vaclav
> Thanks
>> Durgesh Pandey.
>> On Tue, Mar 10, 2015 at 2:49 AM, Dp Docs <sdpan21 at gmail.com> wrote:
>>> Thank you sir for such a nice response. I will look forward to work on
>>> this.
>>> Thanks again
>>> Durgesh Pandey.
>>> On Tue, Mar 10, 2015 at 2:41 AM, Vaclav Petras <wenzeslaus at gmail.com>
>>> wrote:
>>>> On Mon, Mar 9, 2015 at 4:12 PM, Dp Docs <sdpan21 at gmail.com> wrote:
>>>>> I would like to work on this " Add background color to d.legend.".
>>>>> Can you please provide some approach and repository related to problem.
>>>> Once you have GRASS GIS source code from Subversion repository [1], you
>>>> will find d.legend source code in `display/d.legend` directory [2]. You
>>>> should compile GRASS GIS, so you have everything you need for development
>>>> [3].
>>>> d.legend is using GRASS Display library [4]. It would be best if you
>>>> find some display (d.*) module which is already drawing some rectangle,
>>>> polygon or area and get inspiration from there.
>>>> Please keep communication on the mailing list so other can contribute
>>>> or read it too.
>>>> Vaclav
>>>> [1] http://trac.osgeo.org/grass/wiki/DownloadSource
>>>> [2] http://trac.osgeo.org/grass/browser/grass/trunk/display/d.legend
>>>> [3] http://trac.osgeo.org/grass/wiki/GSoC/2015#Tipsforstudents
>>>> [4] http://grass.osgeo.org/programming7/displaylib.html
>>>>> Durgesh Pandey.
>>>>> On Tue, Mar 10, 2015 at 1:36 AM, Vaclav Petras <wenzeslaus at gmail.com>
>>>>> wrote:
>>>>>> On Mon, Mar 9, 2015 at 4:33 AM, Dp Docs <sdpan21 at gmail.com> wrote:
>>>>>> > Hi,
>>>>>> > I Am an undergrad. student from IIIT Hyderabad,India. I believe I
>>>>>> have
>>>>>> > good Programming Knowledge in languages like Python, C/C++. I have
>>>>>> > Already Done Some Projects in these Languages. I have practical
>>>>>> > knowledge in wxPython. I want to work on this Project as a pat of
>>>>>> GSOC
>>>>>> > 2015.
>>>>>> Hi,
>>>>>> this sounds great. As you perhaps noticed students are encouraged [1]
>>>>>> to show their skills by contributing to the project before applications are
>>>>>> evaluated. OSGeo recommends [2] to do some bug fixing or implementation of
>>>>>> small features. You can even try to implement some smaller things from the
>>>>>> GSoC idea itself [3]. I selected some options which might be appropriate:
>>>>>> * Store legend, scale bar, north arrow and text (and potentially
>>>>>> others objects if added) in the workspace (ticket #2369).
>>>>>> * Add units to legend as parameter to d.legend. Optionally add also
>>>>>> title and description. Optionally also put units after each number, not
>>>>>> just to one place in title area as it is now.
>>>>>> * Add possibility to add any image to Map Display (as in Animation
>>>>>> Tool, `g.gui.animation`). Use cases are organization logo and overview maps
>>>>>> (insets).
>>>>>> * Add background color to d.legend. Currently the legend has
>>>>>> transparent background. Background rectangle should include all parts of
>>>>>> the legend including (possible) title. Additional features include rounded
>>>>>> corners, border and opacity settings.
>>>>>> You can select whatever you want but it should be something you are
>>>>>> actually able to finish soon. You can also browse through bug tracker,
>>>>>> components wxGUI and Dispaly [5, 6], to see other options to select from.
>>>>>> Vaclav
>>>>>> [1]
>>>>>> http://wiki.osgeo.org/wiki/Google_Summer_of_Code_Recommendations_for_Students
>>>>>> [2] http://lists.osgeo.org/pipermail/soc/2015-March/002908.html
>>>>>> [3]
>>>>>> http://trac.osgeo.org/grass/wiki/GSoC/2015#CompletebasiccartographysuiteinGRASSGISwxGUIMapDisplay
>>>>>> [4] http://trac.osgeo.org/grass/ticket/2369
>>>>>> [5]
>>>>>> http://trac.osgeo.org/grass/query?status=assigned&status=new&status=reopened&component=wxGUI&order=priority&col=id&col=summary&col=status&col=type&col=priority&col=milestone&col=component
>>>>>> [6]
>>>>>> http://trac.osgeo.org/grass/query?status=assigned&status=new&status=reopened&component=Display&order=priority&col=id&col=summary&col=component&col=status&col=type&col=priority&col=milestone
>>>>>> > I want to know whether someone is already committed to this
>>>>>> > Project or not? I also want to know how to get the mentor's contact
>>>>>> > regarding this Project. I have some Technical Doubts which I would
>>>>>> > like to ask them.
>>>>>> > Thanks
>>>>>> > Durgesh Pandey.
>>>>>> > _______________________________________________
>>>>>> > grass-dev mailing list
>>>>>> > grass-dev at lists.osgeo.org
>>>>>> > http://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20150310/1d40e5cd/attachment.html>
