> hm, I already tried to install `grass7` on Ubuntu 12.04 and it worked. > So how to fix it for the user? Martin If package works on plain Ubuntu without PPAs then the user needs to check which PPAs he's using that's causing the dependency problem. Start by disabling all PPAs except GRASS. Kind Regards, Bas
