[GRASS-dev] [GRASS GIS] #2448: Fontconfig error with cairo on Windows
trac at osgeo.org
Thu Mar 12 16:46:31 PDT 2015
Reporter: annakrat | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.1
Component: Display | Version: 7.0.0
Keywords: font, text, legend, scale bar | Platform: MSWindows 8
Cpu: Unspecified |
Comment(by wenzeslaus):
Replying to [comment:13 hellik]:
> Replying to [comment:12 annakrat]:
> > I made a screencast to see what's in the terminal which just flashes
during the installation. I get:
ERROR: GISRC - variable not set
> > This is the same what happens if you run run_gmkfontcap from windows
command prompt.
> relevant lines of codes
[http://trac.osgeo.org/grass/browser/grass/trunk/mswindows/GRASS-
Installer.nsi.tmpl#L531 g.mkfontcap] and following.
546 FileWrite $0 'set GISBASE=$INSTALL_DIR$\r$\n'
547 FileWrite $0 '$\r$\n'
548 FileWrite $0 'rem set path to freetype dll$\r$\n'
549 FileWrite $0 'set
FREETYPEBASE=$INSTALL_DIR\extrabin;$INSTALL_DIR\msys\bin;$INSTALL_DIR\lib$\r$\n'
550 FileWrite $0 '$\r$\n'
551 FileWrite $0 'rem set dependecies path$\r$\n'
552 FileWrite $0 'set PATH=%FREETYPEBASE%;%PATH%$\r$\n'
> any idea which variable isn't set?
It is the [http://grass.osgeo.org/grass70/manuals/variables.html#list-of-
selected-%28grass-related%29-shell-environment-variables GISRC] variable
which is not set.
The issue is that you have to set it and probably also create a valid
file. It rcfile and `GISRC` variable handling seems nontrivial and I don't
understand what is the actual goal here but perhaps you will be more
successful.
* source:grass/trunk/lib/init/grass.py#L1335
* source:grass/trunk/lib/init/grass.py#L273
We could perhaps avoid this problem altogether if we would just tell GRASS
GIS what to run (#2579), although this might have its own problems during
installation.
One other thing is that it is not clear to me what changed that now GISRC
variable is required but it was not before.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2448#comment:14>
