[GRASS-dev] [GRASS GIS] #2619: v.in.gps compile error
trac at osgeo.org
Fri Mar 13 10:16:18 PDT 2015
Reporter: uwoelfel | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.1
Component: Addons | Version: 7.0.0
Keywords: | Platform: All
Cpu: All |
v.in.gps does not compile due to two small errors:
line 164: '-F', tmp + '.gpx')
should be changed to: '-F', tmp + '.gpx'])
and line 243: atexit.register(cleanup)
should be commented out: # atexit.register(cleanup)
since there is no function 'cleanup'. Probably one should put in something
like the 'cleanup' that does exist in v.out.gps...
Ticket URL: <https://trac.osgeo.org/grass/ticket/2619>
