[GRASS-dev] [GRASS GIS] #2622: Text interface quits immediately when run from zsh shell
trac at osgeo.org
Sat Mar 14 03:09:24 PDT 2015
Reporter: zimmi | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.1
Component: Startup | Version: 6.4.4
Keywords: zsh | Platform: Unspecified
Cpu: x86-64 |
Comment(by zimmi):
Replying to [comment:3 martinl]:
> So doesn't it mean that in your case `$SHELL` variable is not defined
and you want to hardcode it to `bash` when running zsh shell? See
source:grass/trunk/lib/init/grass.py#L911
`$SHELL` variable is set to /bin/zsh by default. If changed to /bin/bash
grass works even when run from zsh.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2622#comment:4>
