[GRASS-dev] [GRASS GIS] #2623: GRASS won't start after creating addons
trac at osgeo.org
Sat Mar 14 07:21:18 PDT 2015
Reporter: ewcgrass | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.1
Component: Default | Version: unspecified
Keywords: | Platform: Unspecified
Cpu: Unspecified |
Having forced addons to install as per Ticket #2598 (still with
grass7.0.1svn-x86_64-unknown-linux-gnu-21_02_2015), GRASS fails to start,
due to what appears to be an issue when creating menu items for the
addons.
The terminal output is as follows:
Cleaning up temporary files...
Starting GRASS GIS...
__________ ___ __________ _______________
/ ____/ __ \/ | / ___/ ___/ / ____/ _/ ___/
/ / __/ /_/ / /| | \__ \\_ \ / / __ / / \__ \
/ /_/ / _, _/ ___ |___/ /__/ / / /_/ // / ___/ /
\____/_/ |_/_/ |_/____/____/ \____/___//____/
Welcome to GRASS GIS 7.0.1svn (r64713)
GRASS GIS homepage: http://grass.osgeo.org
This version running through: Bash Shell (/bin/bash)
Help is available with the command: g.manual -i
See the licence terms with: g.version -c
If required, restart the GUI with: g.gui wxpython
When ready to quit enter: exit
Launching <wxpython> GUI in the background, please wait...
GRASS 7.0.1svn (ns-nad83-utm-25m-10m):~ > Traceback (most recent call
last):
File "/usr/local/grass7.0.1svn-x86_64-unknown-linux-
gnu-21_02_2015/gui/wxpython/wxgui.py", line 142, in <module>
sys.exit(main())
gnu-21_02_2015/gui/wxpython/wxgui.py", line 134, in main
app = GMApp(workspaceFile)
gnu-21_02_2015/gui/wxpython/wxgui.py", line 49, in __init__
wx.App.__init__(self, False)
File "/usr/lib64/python2.7/site-
packages/wx-2.8-gtk2-unicode/wx/_core.py", line 7981, in __init__
self._BootstrapApp()
packages/wx-2.8-gtk2-unicode/wx/_core.py", line 7555, in _BootstrapApp
return _core_.PyApp__BootstrapApp(*args, **kwargs)
gnu-21_02_2015/gui/wxpython/wxgui.py", line 83, in OnInit
workspace = self.workspaceFile)
gnu-21_02_2015/gui/wxpython/lmgr/frame.py", line 121, in __init__
self._moduleTreeBuilder = LayerManagerModuleTree()
gnu-21_02_2015/gui/wxpython/lmgr/menudata.py", line 62, in __init__
MenuTreeModelBuilder.__init__(self, filename,
expandAddons=expandAddons)
gnu-21_02_2015/gui/wxpython/core/menutree.py", line 66, in __init__
expAddons(xmlTree)
gnu-21_02_2015/gui/wxpython/core/toolboxes.py", line 280, in expandAddons
_expandRuntimeModules(root, loadMetadata=True)
gnu-21_02_2015/gui/wxpython/core/toolboxes.py", line 525, in
desc, keywords = _loadMetadata(name)
gnu-21_02_2015/gui/wxpython/core/toolboxes.py", line 558, in _loadMetadata
task = gtask.parse_interface(module)
gnu-21_02_2015/etc/python/grass/script/task.py", line 509, in
parse_interface
tree = etree.fromstring(get_interface_description(name))
File "/usr/lib64/python2.7/xml/etree/ElementTree.py", line 1281, in XML
parser.feed(text)
File "/usr/lib64/python2.7/xml/etree/ElementTree.py", line 1623, in feed
self._raiseerror(v)
File "/usr/lib64/python2.7/xml/etree/ElementTree.py", line 1487, in
_raiseerror
raise err
xml.etree.ElementTree.ParseError: not well-formed (invalid token): line
17, column 19
Changing the name of the ~/.grass7/addons/modules.xml file allows GRASS to
start fine (but obviously with no addon menu items) and the addons appear
to start fine also (i.e. their gui's are created when calling up addons at
the terminal).
Ticket URL: <http://trac.osgeo.org/grass/ticket/2623>
