[GRASS-dev] [GRASS GIS] #2624: r.horizon problem in Windows (horizon_zud)
trac at osgeo.org
Mon Mar 16 01:45:10 PDT 2015
Reporter: rorschach | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.1
Component: Raster | Version: 7.0.0
Keywords: r.horizon, grass70, grass, windows | Platform: MSWindows 8
Cpu: Unspecified |
I think that r.horizon does not create multiple raster maps when used in
raster mode in Windows.
*Note: I am using a dual-booted PC (Ubuntu 14.04 and Windows 8.1)
I ran r.horizon on Windows 8.1 using GRASS 7.0.0. During runtime, it kept
on showing angle: X raster: <horizon_zud> instead of the usual angle: X
raster: horizon_X when being run on Ubuntu.
When looking at the mapset, only 1 map named horizon_zud was added when
running r.horizon on Windows compared to the multiple horizon_X maps when
the command is ran on Ubuntu.
Also, when using r.horizon as an input for r.sun, the results I got on
Windows and Ubuntu where different. This should not have been the case
considering I used the same dataset and input parameters for r.sun and
r.horizon.
Lastly, when I ran r.sun on Ubuntu using the location and mapset
(including the r.horizon results) I created using GRASS 7.0.0 on Windows,
it tells me that the horizon maps are not found.
These things lead me to believe that r.horizon does not create multiple
raster maps on Windows.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2624>
